Hi all, A friend had these on the shelf - no longer needed them after going the W2 route. He didn't do the grinding seen here... Would you have any concerns using these?
I drag raced my dart for years, with hughes cam .600 lift. Never had any problems with factory adjustable rockers. Get some good adjuster bolts and lock nuts they will be fine.
x3. I have two sets of those rockers. One stock the other modified to clear larger springs which was a typical mod made to these over the years. Like said before get new lock nuts and adjuster screws and run them.
