Thoughts on these Adj Rocker Arms
Geo4K
Just your average Gearhead.
New Mexico
Hi all, A friend had these on the shelf - no longer needed them after going the W2 route. He didn't do the grinding seen here... Would you have any concerns using these?
Thanks -
A closer picture would help though it doesn't look any different then what I have seen some in the past to clear springs. As is, I'd run them.
I drag raced my dart for years, with hughes cam .600 lift. Never had any problems with factory adjustable rockers. Get some good adjuster bolts and lock nuts they will be fine.
Agreed x 2 mine look just like that, the machine shop did it to clear my springs.
x3. I have two sets of those rockers. One stock the other modified to clear larger springs which was a typical mod made to these over the years. Like said before get new lock nuts and adjuster screws and run them.
Crane Shaft-Type Rocker Arm Adjusting Screws 99802-2 correct for LA and other.
Very common procedure. I am having to do some like that right now.
