Flyinbrian72duster
Dart and duster
the black mark on distributor is #1 so directly across should be # 6 on compression, the # 6 with tdc locator, and where my dots line up
Yes sir I know I bought a cloyes I wasnt sure about tdc on compression I just posted a couple pics to verify I'm popping my timming chain cherry hereYou've been told which one. More than once. Any good name brand billet set. That means, one that doesn't cost much under 100 bucks and is probably more. If it's not the "billet race" set, that's not the right one.
Chain and sprocketsI'm confused. Are replacing only the chain?
At this point the worst that could happen is your a buck 80 out and thats an easy fix
I thought if the rotor is pointing at #6 I'm on compressionAt this point the worst that could happen is your a buck 80 out and thats an easy fix
So what take the valve cover off watch the rockers and when they both dont move and its tdc and rotor is at #6 I'm on compressionIf on compression stroke
Sorry I didnt mean to make things worse, it's just the way I do it. Yes you are on #6, as per the gears, but I dont see rotor?
I'll confuse things more...my brain ain't right, but a crank turns 2 revolutions per complete firing of all 8 cylinders. 2 revolutions is 720*. Well 720* divided by 8 cyl gives us 90*. So every 90*(or 1/4turn) of crankshaft gives you the next cylinder in the firing order(18436572) firing.
Yea I'm getting more confusedSorry I didnt mean to make things worse, it's just the way I do it. Yes you are on #6, as per the gears, but I dont see rotor?
at #6 the black mark on the side of distributor is #1Sorry about that.
Your sprocket positions are good, where is rotor pointing?
Another way is EOIC, which means
Bump the engine until the EXHAUST valve starts to OPEN and then adjust the intake on that cylinder
Bump the engine until the INTAKE valve has opened and is almost CLOSED and then adjust the exhaust on that cylinder
Comp Cams
Steve Morris Engines
Put the fuel pump eccentric on and see if they dont counter balance it ..View attachment 1715302770
I've always heard that Cloyes is the best but can someone please explain how this Cloyes 9-3603X9 can not cause some inbalance problems in a running engine with all that weight removed from one side of the cam gear?
I have a couple in stock and that's my plan. I bought a hardware kit, too and it includes the drip tab.What about adding a tensioner to your single row Krooser? Only about $35 and has built in oil slinger.
I should mention that the late, great Pro Stock racer Bill Grumpy Jenkins used stock SBC timing sets in his engines...complete with the aluminum top sprocket and the nylon gears. Liked them because that deal gave off the least harmonics to the valve train!!!
How do you argue with that thinking?
