What size are the tires with the hotrod photo and the photo with the trailer are they the same size tires.Small bolt 15x8 4 1/4 back space . Brown car
Big bolt 15x8 4 1/2 back space. Orange car
tires 275 -60- 15
With mini tubbed car
15x12 7 1/2 back space. Orange car last two pictures
tires 29x14.5
They are 29x14.5 Hoosier's on 15x12 inch wheels. 7 1/2 BS, standard width a-body rear, We went to a 28x14.5 and they fit better. A picture with 28'sWhat size are the tires with the hotrod photo and the photo with the trailer are they the same size tires.
Curious,did your 60 foot change any when you went to the 28s?They are 29x14.5 Hoosier's on 15x12 inch wheels. 7 1/2 BS, standard width a-body rear, We went to a 28x14.5 and they fit better. A picture with 28's
You mean I can put 276/60/15 tires on without mini tubs?
A video to go with the picture.
when I measured the width of my duster's wheelwell, I got about 12.3" wide to the inside lip of the wheelwell. that lip is about an inch wide, so you could trim or roll it for more clearance. theoretically being super precise on backspacing, wheelwell wise, you should be able to fit up to 295's in a stock wheelwell (12.3"=312mm)On a Duster, yes. As long as you get the wheel centered up with the proper backspace for your car.
fair, granted you can probably get another 3/4" by trimming or rolling the quarter panel lip (it's over an inch wide on my car)....run some 20's with 3" sidewalls and an IRS that won't have the side-side flex of leaf springs on shackles then maybe as well....lol.
Sure, as long as body roll isn’t a thing. Or sidewalk flex. Or suspension flex.
So no, not even theoretically. Because even theory can calculate how much the sidewall will flex.
Realistically you need a 1/2” for clearance on the quarter side, and not much less than 3/8” on the spring side unless you’re running really low profile tires.
Well i have the tires on 295 65 15 and i did roll up the lip but i did not really need to because the the fender sit above the tire like the 275 60 15s did , I do have shackles on it . To this point so far and from what i have done I have not had any issues.fair, granted you can probably get another 3/4" by trimming or rolling the quarter panel lip (it's over an inch wide on my car)....run some 20's with 3" sidewalls and an IRS that won't have the side-side flex of leaf springs on shackles then maybe as well....
and if he's only going 1/4 mile at a time in a straight line, I'm guessing you can get away with less clearance as well, since you typically don't have to give as much clearance for lateral movement...
