beanhead
All customers are now required to let this clip play during the entirety of your visit to this thread.
Thank you for your cooperation.
-The Mgmt
Yeah kind of like tearing a engine down and then physically measuring the crank just to see if it even needs ground or if a simple polishing with emery cloth will work. Or looking and measuring a cylinder bore to see if it actually needs bored or if a simple honing will keep it within specs. Ect... physically measuring whether parts are within spec or not. Instead of throwing money at itAin't that the truth? I wish I could afford how it "oughtta" be done. I have to do what I have to do......or find another hobby. What would be the fun in that? I find it challenging to do it under the gun of a tight budget. For people who have the money, it's easy to just open the checkbook. But when you do basically the same thing on a strict budget, it's more rewarding.
Like when I recently rebuilt a little slant 6 electronic distributor and welded up and refiled the slots, put light advance springs in it and got it in ready to run shape. Not everybody can do it and not everybody wants to do it. Some people would just open their checkbook. I enjoy making something good out of something not so good and modifying it to suit my needs. It's a lot of fun and very rewarding. And a nice byproduct is, it saves me money.
Hmm so you just going to throw money at it without even measuring.. makes sense that you would do that. As it's pretty clear already that you have no idea as to why machine work can't and won't fix core shift. Then you try and bandage it up by throwing more money at a junk block. The friend I had probably would have scrapped your high dollar junk in the salvage yard. So go study core shift. And why it can't be fixed. And all of the areas that it effects and also why after spinning a main that the block is now crooked. Don't be cheap and lazy little buddy. Have faith you will get there. Just takes timeNo sense measuring anything if you are just going to run it. When the main bearing clearance is .0022 plus a couple of tenths minus zero and you have a journal with .0003 taper it’s already out of spec. I won’t run that. If you measure the bores and it has .0010 taper it will take another thou and a half to get it straight so that means the bore will be too big for the pistons. You can measure all you want but if you are using the FSM tolerances they are so sloppy it’s not worth measuring. Maybe you should go hang out with some real engine builders and see what they do. Unless you don’t want to learn little buddy.
When you have a crank turned down say 0.010/0.010 and order a set of main bearings then using some 5W30 to oil the bearings and torque the main caps down you should be able to grab the 1 1/4 inch bolt and turn the crank. How easy it spins will tell you if you really need to have the Main web align honed.
When they align hone they can only go so far and if it will not clean up then a align bore will be needed. But an align bore and hone will mess up your timing chain spec as they take some metal off the block and the main caps and then bore them out to standard diameter. This little bit raises the crank up in the block 1/2 the over bore and the timing chain will be loose. NOT my choice of doing an engine and ONLY to be done on a 'Numbers Matching' block that is worth only what the car is worth with it.
My 1978 LRT has a warranty replacement block due to a chronic rear main leak. It has a huge W in the vin number area.
The original 360 was found to have a major defect in #5 main cap. The grove for the rope seal was too deep and the seal did not touch the crank.
To fix the block would have required a new cap and align bore then hone. They could have shimmed the rope seal up and it may have lasted till after the warranty expired.
I did not own the truck back then, I would have bought that block from the dealer then replaced the #5 cap.
Not if it's done correctly it won't change a thing. The correct procedure is to knock a little off the main caps where they meet the block, then assemble and torque them to spec in place. Then set it up on the bar and BARELY clean the block side up while taking the most material out of the caps. Doing it this way will change nothing concerning the timing chain. I've even seen shops lightly spray paint the crank saddles in the block so they can remove the absolute minimum from the block side. If the shop refuses to do it that way, find a new one.
of course you measure it, then you 'know' if the crank journals are within spec or if they do need to be ground and you 'know' if the bores have too much taper so will need to be bored or not. measuring is cheap to find out if machining (which is expensive) is required or not. your checkbook approach was made very clear in this one post, leave the rest to the cheapskates.No sense measuring anything if you are just going to run it. When the main bearing clearance is .0022 plus a couple of tenths minus zero and you have a journal with .0003 taper it’s already out of spec. I won’t run that. If you measure the bores and it has .0010 taper it will take another thou and a half to get it straight so that means the bore will be too big for the pistons. You can measure all you want but if you are using the FSM tolerances they are so sloppy it’s not worth measuring. Maybe you should go hang out with some real engine builders and see what they do. Unless you don’t want to learn little buddy.
It's funny, I never see any machine work being done in the pits when they run those 12,000 plus HP top fuel engines. I'm sure they may do a little.....mostly all I see are bearing and ring changes and the like. I guess they must not know the speed secrets of doing machine work on builds. You'd figure with the pounding those engines take, they'd want everything perfect, yet they run a lot of the same hard parts over and over. And win.
Oh my it's the line bored, coreshifted, tight clearance forged piston, half assed balanced soap box standing guy. Back to tell the lowley peons how to build a engine right.Have you never heard the motto in the fuel pits??? I may not get it exactly as they say it, but this is close. Measure it with a yard stick, cut it with an axe. There isn’t much precision in a fuel engine. Clearances are humongous. Pro Stock is a different horse altogether. You don’t see them slapping new bearings or pistons in at the track. They have much closer clearances and tolerances than a fuel engine does. They run water thin oil where a fuel burner uses a 70 grade oil that when up to temperature is more like fudge than oil. Two different beasts for sure.
I have seen a 440 block that a machinist's straight edge rocked on #3 saddle. Yes they did spray paint the saddles and bored to just wiping the paint off. But when done the timing chain was sloppy. It went into a motorhome. It was not one of my builds, I had no pony in that show. The motorhome owner demanded they just put it together as is. Shop foreman said no and Owner took it somewhere else. #3 bearing was thru the copper and on the steel before align bore/hone. Crank did clean up at 0.040" but still showed shadow marks.
I would have scraped the whole engine. It had been over heated so many times.
The foreman said he thought #3 was the only one that was true deck height. That block had major core shift well before all the overheat cycles that warped other stuff out of spec.
I was a US ARMY SP4 and worked part time at this NAPA machine shop @ $0.95 an hour. My job was to knock down the long blocks, box and tag everything. I had to straight edge most surfaces and chart them. Just about everything on this engine was red tagged.
I agree, a newer 5.2 with a $3000 budget could make for a decent engine. a 318 LA not so much.Oh my it's the line bored, coreshifted, tight clearance forged piston, half assed balanced soap box standing guy. Back to tell the lowley peons how to build a engine right.
We ain't so smart boss but we can lift heavy thangs.
Meanwhile for the purpose of this thread I'm going to go yank one of these running 5.2's out of a ram or dakota that's been factory proven and still running. Then maybe do some valve grinding/polishing.
Then drop a camshaft in it. And put it in my 72 duster and go out and embarras quite a few of the $6,000 boat anchors. And have maybe $1,500 into it.
Thread is 318 or 340 you have $3,000 what you going to do? No more than $3,000. No saving for more money , no pimping your sister or mom out for more money I'm going to take the 318 on that all day
I get what your saying, I'm just saying what I would do back in the day with my limited budget.You can’t use a 5.2 because the OP didn’t write it in his rules package. And I doubt I’d run the stock pistons and bores in one of those either. Factory machining was never better than decent.
