this may sound stupid but sounds like the pickup coil took a dump or its set to close just a thought
I still think it's fuel.
OK, IF I understand what you did and what happened.......................please correct me if I'm wrong.
The fact that running a direct line from the battery to the regulator "cured" the problem indicates that you DO have voltage drop in the ignition harness. Visualize in your mind the path (stock wiring)
Battery -- fuse link -- bulkhead connector -- ammeter circuit -- ignition switch connector -- through the switch -- back out the switch connector on dark blue "run" line -- back out the bulkhead connector -- to the ignition system, the regulator "I" terminal, and the alternator field on 70/ later isolated field systems.
well remember i just "fixed my last no charge issue with running a wire from the alt to starter relay stud... there is no fuseable link as the bulkhead is bypassed (alt lead in and out only)
ANY bad connection or drop in this area can cause this surge. In rare cases, surge can be caused by what amounts to R.F. interference from something like a high power ignition system, which can produce noise on the 12V buss and interfere.
only have a MSD street fire box so i dont think its that
If it won't crank you "broke" the yellow going to the start relay, most likely. Sounds like you have numerous problems with the harness/ bulkhead connector.
Must be frustrating....................
Originally Posted by SpeedThrills
Have you checked fuel volume yet?
Moper added:
I'd also second this. Get a clean 5gal bucket, mark it into 5ths, and flow the pump thru the fuel log into the bucket. Use a stopwatch to see how many seconds it takes to pump 1 gal.
This is from one of your other threads on this problem. (You're all over the place.) I can only guess that you do not understand the theory of FUEL VOLUME VS. FUEL PRESSURE. I don't want to hear about this pump or that regulator. TEST FOR FUEL VOLUME!!! TEST! DON'T BOLT ON MORE PUMPS, TEST!!!!!!!!!!!!!!!!!!!!! DID I MENTION TO TEST?????????? WHY ASK FOR HELP IF YOU'RE GOING TO IGNORE IT????!!!!!!!!! YOU COULD PUT THAT HOLLEY BLACK PUMP ON AND STILL HAVE INSUFFICIENT VOLUME! BUT YOU"LL NEVER KNOW BECAUSE YOU WON"T TEST!!!!!!!! TEST IT BEFORE YOU PUT THE BLACK PUMP ON.
Dam it, dude, we're trying to help, and you IGNORE a very critical and basic test that will give you valuable data!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:violent1::violent1::violent1::violent1::violent1::violent1::violent1:
I'm gettin a headache.
well i got a black pump and 750 on there way
i doubt that you really need a holley black pump,i have a blue on my 13.1 340 and its never ran out of fuel on the motor and im sure the 750 mite be over board to....but thats just my two cents
Thanks for not taking my rant personally. I've been reading all of these posts and it's been killin' me!
That's why volume is important. If you have enough volume at the right pressure, at idle, you'll have enough under acceleration.lol im rhick skinned... and as you say it should be sooner on the diag check list...
my only question is with the car stationary vs moving alot of things change, extra force on the fuel in order to get it up the tube... how do you test for that?
*crickets*
but
i didn't know it could be set to close... i always here about how you file them down even so you can get it really close...
Yes, it is possible to have the gap too small.
On my previous race car I changed the msd pickup and went to a digital 6 ignition at the same time and it developed a miss at around 5700 rpm and my tach being triggered off of the box would sometimes trigger the shift light at the wrong time. I thought the msd dig 6 box was bad and sent it back to msd. They found nothing wrong with it but did send me a new one anyway and I still had the problem. I made ground and power wiring changes but nothing helped. One day someone told me to turn the rev limiter off on the dig 6 and the car ran fine so I was still blaming the box again. Anyway it turned out that when I setup the pickup gap to .003" it was too close. I changed it to .025" and all my problems went away.
One thing you have to make sure is when you tighten down the msd pickup you don't over tighten it and crack it because it will cause a miss too. AND the magnet has to be oriented right.
I'm late to a really long thread and i need to go and read it in depth. But 35yrs ago i chased this very same problem and replacing the rocker shafts, arms and spacing them properly took a 340 from 5500 to 7000+
Im sure this was mentioned early, but if i find any ideas to add after reading i'll post'em.
