racerhog
RacerHog likes his Mopars
YA might want to fudge it just a little higher..Or Try leave a little room to shim it up if you need to...
Did you look at K-Motion springs?
Might need to cut the pockets and shorten the guide for the stem seal?
How much spring you will need is in part dictated by the shape of the cam lobe (profile) and RPM. You could always go to a little less rearend gear also,lol.
ok for giggles opened it up to .025... it wouldn't start... then .020 and it wouldn't... so it looks like .016 is it...
That doesn't seem right to me since you are using an MSD box.
From what I understand the Mopar pickup is basically the same as the MSD pickup and MSD recommends a setting of .018" to .030"
http://c452191.r91.cf2.rackcdn.com/images/bccx/image/84661_frm30015.pdf
That being said those pickups have a permanent magnet and over time that magnet can lose some of it's strength which will result in a weaker trigger signal.
PSI Also Dose a great job helping with valvetrain issues....
http://www.psisprings.com/
If I recall... 340 Dual springs would fit... ONLY if you cut down the guide and also you have to cut down the spring pocket... They were good to like.... .490 lift or there about...
I think "Racer Brown" was were I got the Info.... But I cant find it out in my shop..... Figures.... Sheesh
That's what I'm thinkin. I mean I know valve spring pressure is important, but damn, 350 pounds is a ton. I wouldn't dare go to 400 +.
I'm more worried about the valve failing than I am the spring rate for the RPM....
Sounds like you don't have enough volume. I found this: http://forums.corvetteforum.com/c1-...5-hi-volume-mechanical-fuel-pump-testing.html
About half way down the first post he mentions how much fuel you should pump for a given car. He's talking faster, more powerful cars, but it seems you're right, the 60 gph you're seeing isn't enough.
New parts don't mean good parts. Go through your delivery system closely.
I don't have anything running to do a test on. You know anyone whose car you could test to compare?
MORE crickets! -I'm not sure why I'm still tryin'.
A quick thought, what are you using for feeler gauges when setting the gap in the distributor? I believe it has to be something non magnetic. I believe using regular steel feeler gauges screws either the pick up, or the reluctor up some how.
Yeah put the valve lash back where the card says it needs to be. I think you're gettin close dude.
So I guess you mean it runs like a charm, but it still misses? A little confusing.ok so got the carb back... installed it and ran like a charm...
so i went and tried lashing the valves back to what the cam card said... opened them to .024/.024 hot from .016/.020 hot and ran it... had about 2" more vacuum at idle for the same rpm and maybe a half inch more at cruse...
but still missing...
so now what...
