This may sound stupid, what fuel cell/tank are you running ?
So I guess you mean it runs like a charm, but it still misses? A little confusing.
Glad you got your volume up, one less thing to wonder about.
No it actually sounds smart as all hell. That's what we've been talkin about next. lol
If I remember right, the Hyper Pac intake had equal length runners. The center two curved back and forth to make them longer.
Ed, have you ran a different coil by chance? I see in your other restoration thread you have a blaster 2. I have seen these coils cause your complaint.
Ian
Set your tach for 8 cyl and it wont break up at 5800:violent1:
LOL... so you have your set for 4 cyl??
Clifford doesn't know their *** from a hole in the ground. There is no such thing as "chrome moly" rings. They are cast, chrmoe, or moly. Chrome moly rings do not and never have existed. Ever. Dumbasses.
lol... desides that... what would cause molys not to seal?
Dude, your rings are fine.
I am thinking it is your ignition. One way to test, is to bench test it. I use a drill press to spin the distributor and a piece of metal drilled and threaded for the plugs. Use the coil and ignition box, ballast and battery from your car. You need to use heavy wire to connect the grounds at distributor, box, and plug metal and battery (-). The distributor turning at 3000 RPM simulates the engine at 6000. Viewing the spark plugs may show the problem. I view the primary voltage with a scope to see the dwell and peak voltage. Depending on wiring, you may have noise issues related to spark and distributor pick-up, or low voltage condition creating the miss. A spark plug wire close or contacting the pick-up wires could be a problem. Start at a lower RPM first in insure all is fine.
Valves.
