Mad Dart
Nothing to see Here!
A little eye candy for you. I did have to clearance the upper and lower coilover mounts to get the clear the Strange Engineering Coilovers, but only took a couple of minutes. I clearanced where my finger is pointing.
Looks really good!
One thing I thought about was if the upper shock mount is hanging down some where the upper shock bolts thru the mount, ride height will need to be raised depending on the shock length. Something to consider when making your shock selection for those guys looking to lower the car without drop spindles.
Your shock selection gets narrow in this situation. The smaller length shocks have a lot less travel like 2.5 ".
