i mean...my car runs fine...its stock for now...ive just been told that unlike most cars, you dont want to keep your engine as cold as you can because of that, especialy as you start to modify alot...im in the prosses of drawing up plans so i can fab an intake to rid myself of this problem all together...but i was just wondering how other people were doing it.
Manifold heat cures this problem. There is already an equal length runner intake made by an Australian company,its called the Hurricane. Or you could use a side draft intake,also have equal length runners.
Do some internet research,you would be amazed at what you find.
and ask mark (MadMAx/6) how that works with a performance build
Which are you talking about? Manifold heat,the Hurricane,or the side drafts? The hurricane is a good street intake,but I wouldnt use it in marks application either,but side drafts on the other hand.....
yea the hurricane... stock sized ports...
by the way, i ment to ask...dos the 73 225 have hardend valve seats?
yes but apparently they are flame hardened
i see...so as long as i dont open up my ports ill be fine?...by the...do they make performance heads or are you just stuck to upgrading stock ones
you can port it just make sure not to nick the valve seats.. if you have never ported a cylinder head I'd suggest finding some cheap Ford of Chevy heads to practice on- it's VERY easy to F a head up the most important thing is to take your time..im guessing thats a no then?so...do most people just run with un altered heads on these? even if they are upgrading?
Induction hardened, that method dose not penetrate too deeply, and when oversized valves are installed, or sometimes a valve job is performed, new hardened exhaust seats have to be installed. They are not very expensive to install.
