I'm leaning hard that way.I vote exit to atmosphere, there has been proven hp increase when does this way. Alot of people reroute it back due to noise it makes, I loved and miss the sound of my srt4 with a 60 trim turbo and my wg dumped under the car, sounds awesome to me
The a/f wont be effected by dumping the wastegate to the atmoshpere, unless some how oxygen goes back up the wastegate. The O2 only needs a small sample of exhaust to get its reading. If the wastegate dumped all of the exhaust out of it when open it would be a different story.I'd vent to the downpipe. I don't know how you'd gain a noticeable amount of power by exiting to atmosphere. It may be easier or smoother for the gate to open since there isn't as much pressure in the atmosphere. But then you must think about O2 sensor. I'd want all my exhaust passing over the sensor, not most. They do have a unique sound vented open.
How sweet!my 6 month old puppy was down there with me and I think she stole my throttle lever to the tranny and hid it somewhere out side.
Yeah me either unfortunately in ohio the winters are unpredictable so it wont be till springish till I see how she runs. Not sure why people always refer to cars as shes.Sounds good, can't wait to see the update on the gains
Seem like good turbos, but we will see once I get some miles behind it.Not sure either, just always do. How do you like the quality of those turbos? Once I get mine up might look to upgrade the turbos later from the gt45s to twin 77mm
yeah they are dry, using moroso gaskets. It really appears to be coming from the base of the distributor.Glad to hear you got it out and was able to enjoy it a bit. Bummer about the oil leak, valve cover gaskets all dry too?
worth a shot, I'm going to take the intake off once more just to double check. Its weird it just started leaking out of no where.Well if the o ring is good, think making a gasket for the base to block would help? Cant remember if they have one or not lol its been a while
