danielb927
Always good to see another young gun around here! I don't know how you could like one of those tin-can mufflers on a Honda after you've heard a v-8, but at least some of us know what's up!
I feel that my car will run an 11.99 with whats in my sig. It has trapped in a 1/4 at 110 but with a worse 60' now that I got the 60' times down I think it will do it. So all this wanting to go faster has got me thinking. How much would I notice in the times with a stroker kit (408), larger cam maybe roller to match heads, ported eddy heads to the max, and pump gas friendly compression.
Would tens be possible on pump gas and not spending over 5k? NO NITROUS!
A stock 2009 Viper has gone in the 10s off the showroom floor with a good driver...
I prob would cage it later IF it ran that fast, but not before. The car lives on the street and sees a track maybe 10 times a year. I am not building some purpose built race car just a pump gas street car that is good at what it does.
Flyfish please refresh my memory. Was it comp cam and lifters?
Another question. Would I notice moving the battery to the trunk any in my 60' times? Maybe hike the left front a little more?
Yup, there's a good possibility that any substantial amount of weight like a battery moved to the rear will help with weight transfer.
Viperred,moving my battery to the trunk also,before the season starts,and as already stated if you don't want to run more gear then stroke it,my 416 ran consistent 11.0's with only 3.91's.and i'm certain it would have touch the 10's,but i blew the motor just after i installed the 4.30's..only 19 and a ride as nice as that your a lucky man..:-D:-D
what the H is a 440 w8 motor and stock suspension in a f en mustang what do think we were all born yesterday!!!!!!!!!!!!!I would just stroke it,port the heads change,cam leave the gears that are in it.You need torque to get you out of the hole.
