pettybludart
It was just over $500 plus shipping.I,m very happy with their service,was top notch to deal with.:cheers:
I am loving every bit of this build!! Everything looks amazing!! I mustve spent three hours today going through every page and it was well worth the read. Ive been planning to build a turbo setup for my duster's 408 in stages over the next couple years; this thread i can already tell will help me immensley!! Ive been planning on running a MSII and turbo cam until i can get enough downtime and money to purchase/install the turbo setup. Im thinking a pair of holset turbos with an air-to-air intercooler...
After reading through the entire thread i still have a few unanswered questions (or answers that i cant remember or find again): Since this as you said will be a street car 75% of the time, why did you choose to run a water to air intercooler? Isnt it more efficient at the track, but through the streets will it be less than optimal?
I am also curious as to what brand blowoff valves and wastegates you have..
Thanks a lot, and keep up the great work; i cant wait for more updates!!
Thanks, great info! ...I am only going off of what i have heard when i say water to air is more efficient. Although with colder water than ambient temp. of air it could make a cooler charge; i dont know the difference in pressure loss between the two types though. Since my car will be seeing like 99% street use, id like to minimize the moving parts and such. Cant wait to see the progress and how the MSII goes together.
Are those hedders gonna work/fit Louis?I could be wrong,but to me they don,t look like they,ll fit.Good luck getting it to the dyno.:thumrigh:
Louis,I,ve just never seen shory,s used on a SBM other than the SpitFires.Hope all works out for ya.Will be watching..
Oh and the engine looks awesome!!:hello1:
There is a guy on FABO that uses a set just like this only he has a Single Turbo on a 318. He has had his on there for a good while with no problems at all.
Mine Dumps straight off the collector to a 2 1/2" pipe to a 3" Pipe and up into the Turbo Flanges on both sides. Should be plenty of flow out the exhaust.
We will see when it hits the Dyno. I say at least 425HP 425TQ to the tires!:smile:
Oops I mean 825hp 825Tq to the tires!
I'm tempted to take it to the dyno for you. Since you've gotten more busy with work, I've gotten less busy. My CO told me today to stop staying at work so much and take advantage of my new position. Guess I better follow orders!!
You can keep the movement to a minimum by strategically tacking and welding it off. I never complete 1 full circle weld. I do it in quarters and opposite on a different joint until i get all the way around it. It seems to help a whole bunch.
What exactly moved on yours?
