fishy68
Tyr Fryr's Inc.
That's basically itOk, so no one's asked, so I will. What is cam "delamination" exactly? From one of the pictures, it appears to be the peeling back of the layers of steel the cam is made of.
Excessive heat is one cause. Junk metal is anotherAnd what causes it?
Excessive heat from lack of oil? LolExcessive heat is one cause. Junk metal is another
I just have to wonder even with the "junk" metal if the oil problem is true and it was fixed if it would be and issue still. Because with proper lubrication and roller lifters there cant be that much friction on the cam even if it is made from junk China metal! Just a thought.From China, I just bet.
I have zero experience with the G3 hemi so all I have to go on is what I've read here about the problem they have but good lubrication is key to making even junk live longI just have to wonder even with the "junk" metal if the oil problem is true and it was fixed if it would be and issue still. Because with proper lubrication and roller lifters there cant be that much friction on the cam even if it is made from junk China metal! Just a thought.
As cheap as they are they'd have to beFrom China, I just bet.
I threw a 80 dollar summit cam in a 318 one time back then I knew nothing about building a engine. And put that engine in my 72 barracuda drove it for years and sold it to a guy that drove it. Never had any problems out of it. It was weak as pond water tho! I think that was more related to me not knowing what I was doing and the timing and carb tune was trash! Lol$80 right from the Chrysler parts dept
That 80 dollar summit cam was probably ground on a suitable core, not a potmetal mess from Chinese metal slushI threw a 80 dollar summit cam in a 318 one time back then I knew nothing about building a engine. And put that engine in my 72 barracuda drove it for years and sold it to a guy that drove it. Never had any problems out of it. It was weak as pond water tho! I think that was more related to me not knowing what I was doing and the timing and carb tune was trash! Lol
That is a good point! In the pics above it doesn't even look like the parts that are chipped away are within the roller contact area! For the most part! So that kinda eliminates "wear"You have a roller wheel, rolling along the lobe, the majority of the load is actually on the needle rollers in the lifter, all the wheel has to do is roll up and down the lobe. That is, until peices of that lobe, begin to flake off in chunks, as seen in the previous photo. No amount of oil on the surface is gonna prevent a whole chunk of metal from separating UNDER the wear surface. (Base casting of metal) Its NOT a heat issue, there is less friction, therefore heat, with a roller versus a flat tappet, otherwise flat tappet cams would just RIP layers of metal off in the same fashion. Put a quality cam in it, the engine will run 300k miles. With the same oiling "flaws" think about it
I AGREE I had a 1970 318 that went 350,000 miles ate a few plastic timming gears though. I also had a ram 440 1977 that went over 500,000 mile with no problems , of course I used quality oil and filters and changed at regulsar intervalsMy 70 Chargers 383 magnum ran flawlessly up thru 185k . I rebuilt it then just for the hell of it .
Its JOHNSON lifter that has the improved lifter. Their web page explains it.I've heard that there are two different Johnson lifter companies. Johnson vs. Johnson Hylift? Which is the one to use?
Cams are not layered....solid steel. The bad lifter grinds away the lobe.Ok, so no one's asked, so I will. What is cam "delamination" exactly? From one of the pictures, it appears to be the peeling back of the layers of steel the cam is made of.
Didn't you allready see the picture of the cam lobe missing peices of metal with a perfectly intact roller allready posted in the thread? I have had a boatload of 5.7s in my shop for cam replacement, there is ALLWAYS bad lobes with a otherwise perfect roller still rolling on it. The lifters fail AFTER the camCams are not layered....solid steel. The bad lifter grinds away the lobe.
Well now, a boatload, is still less than a thousand!43 has probably seen a thousand times more than me!!
