Krooser
Building Chinese Free Engines since 1959...
Fact is camshafts or either cast or ground on a solid billet. What happens during a failure is another thing altogether.Didn't you allready see the picture of the cam lobe missing peices of metal with a perfectly intact roller allready posted in the thread? I have had a boatload of 5.7s in my shop for cam replacement, there is ALLWAYS bad lobes with a otherwise perfect roller still rolling on it. The lifters fail AFTER the cam
The cams, whether Mopar, Ford, Honda or any other USA manufactured brand all come from one of two companies...CMC or CWC. And there are only a couple different materials and heat treat procedure for every cam made. Tried and true formulas.
The LS I believe oils the roller and the Hemi does not. The Johnson lifter introduces pressurized oil to the roller via a drilled passage as I see it. That oil makes the difference.
