Updated SPITFIRE HEADER INSTALL 63-66 A-body
Early A-Body Discussions
Should this be made a STICKY?
Poll closed Oct 17, 2008.
  1. yes, very helpful
    76.5%
  2. no, sucks
    23.5%
  1. 65DrtGT
    65DrtGT Well-Known Member
    130
    3
    Feb 18, 2008
    Missouri
    Local Time:
    2:49 AM
    I have a 65 Dart GT with a 318 4speed i bought a set of spitfires a few years ago had eng dinod with them well Finally getting eng bh and tranny in BUT there is NO way the drivers side header will fit between the block and steering shaft also they dump Straight into the tortion bar ???? help i really Dont want to run stock manifolds Unless i have to
  2. madmax669
    madmax669 Well-Known Member
    67
    0
    Jan 25, 2015
    arlington tx
    Local Time:
    2:49 AM
    looks like the left header outlet is dumping out at the torsion bar
  3. Killer6
    Killer6 Well-Known Member
    2,430
    809
    Mar 9, 2015
    PA
    Local Time:
    2:49 AM
    The theory & anecdotal testimony is that on cold days/nites shutting down
    the engine hot w/open headers creates a natural convection draft thru any open
    valves.primarily ones on overlap thus subjecting the very hot exh valve to uneven
    thermal stress as colder air ends up pulling past. warped valve, crap compression
    burned valve after a few more runs. thats it
  4. paulscars
    paulscars Well-Known Member
    114
    3
    Jan 4, 2012
    canada
    Local Time:
    2:49 AM
    thanks for the explanation. i was still wondering even though i asked the question in july of 2013. lol #-o
  5. paulscars
    114
    3
    Jan 4, 2012
    canada
    Local Time:
    2:49 AM
    so i guess that if i dont shove steel wool up my exhaust my engine is going to run like shit cause i will warp a valve and have shitty compression and burn a valve on the next run? wow. you learn something new every day. i knew steel wool had more than one use.
  6. BIGFISH
    BIGFISH Well-Known Member
    46
    0
    Sep 5, 2005
    Nevada City, CA
    Local Time:
    12:49 AM
    As far as Durango/Dakota manifolds go, I ordered a set of Dorman replacement manifolds from Summit Racing and they do not fit. Passenger side manifold is too thick/wide and hits inner fender as well as the drivers side hanging up on the steering coupler. Also the dump on both sides is at a bad angle. They could be made to fit, but I felt it was more work than it's worth. I'm now in the process of modifying Summit brand Durango/Dakota headers to fit. A bit of work but it is gonna be a better fit and I won't have to use dual exhaust like the TTI setup.
  7. bigjim64
    bigjim64 Active Member
    27
    2
    Jun 14, 2010
    Ottawa Ontario
    Local Time:
    2:49 AM
    wow looks great a lot less hassle than the tti i have in my 64 did you have to do anything with the oil filter?
  8. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    53,156
    38675
    Jan 18, 2006
    Iowa
    Local Time:
    2:49 AM
    10 year old thread but Dave was online here today. May be he still has those headers on.
    • Like Like x 1
    • daves66valiant
      daves66valiant 68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
      3,180
      1174
      Nov 24, 2005
      SoCal
      Local Time:
      12:49 AM
      Easy install but Sold them long ago. Have a set of Doug’s on that car now. 90* oil filter adapter worked well. I have one of the early-a tti sets on my convertible valiant as well. Pita installing those but they look great.
    • dart4forte
      dart4forte FABO Gold Member FABO Gold Member
      4,679
      1113
      May 28, 2004
      Mesa, AZ
      Local Time:
      7:49 AM
      So,is Herold still around?
    • daves66valiant
      3,180
      1174
      Nov 24, 2005
      SoCal
      Local Time:
      12:49 AM
      No idea if he’s around. I doubt it honestly.
    • abodyjoe
      abodyjoe Well-Known Member
      20,909
      6193
      May 22, 2004
      Berlin,N.J. 08009
      Local Time:
      3:49 AM
      Haven't heard anything about him in years.
    • rdunnam
      rdunnam RDunnam
      55
      12
      May 31, 2011
      Tupelo, MS
      Local Time:
      2:49 AM
      For planning purposes, using Schumacher mounts, or any other brand, to install any small block in place of a six (six K-frame remains) or an eight (into eight K-frame) versus the OEM engine mounts on an eight replacing an eight, for header clearance purposes, does the engine end up being at the same spot from steering shaft and other engine bay components, etc, correct? I read through this old thread and I know there's hundreds of threads out there on headers being installed in early A's, maybe more recent threads for sure (than this Spitfire thread) on TTI's and even other brands installed into the early A's, I'm thinking if different motor mounts (brands) can make a small difference when this guy has to bend the header in this spot or that spot to get his to work when the next guy posting did not, etc. I guess what I'm asking, have people run across motor mount dimensional differences causing headers install differences (clearances)?
    • abodyjoe
      20,909
      6193
      May 22, 2004
      Berlin,N.J. 08009
      Local Time:
      3:49 AM
      conversion mounts are supposed to put the new motor where it would have come stock.. tti even gives you measurements for the crank centerline sice the tolerances on some of these cars are horrible..
      • Thanks! Thanks! x 1
