khuebner250
I modified my trans crossover and trans mount. I ended up cutting out the sides of the channel and rewelding to keep as much strength as possible.
Yes, I saw the pictures..looks good....I was looking around to see if anyone else had done this another way? Always good ideas here.... my thought was to weld (alum) a bracket to bolt on the factory bracket as original. IM not sure if this would work or not? Alum weld Tig weld it.....your way works and seems simple enough. What about the kick down?Project`67 Dart GT 340 A500
Got pic on here how I did it, works great . Nick down is same as stock.
I was little worried about mounting to mount instead of trans like factory due to flex . But thought I would try it since my car and not testing on a customer s and works great after many miles no problem at all. Kick down is stock .
I haven't thought that far ahead. I was trying to get everything mocked up and the chassis squared away before it went to body. But will probably go the cable route.
I spoke with Chris at US Car Tool yesterday about the 518 cross member. He stated clearly the sheet metal in the tunnel would not have to be removed with the use of their Crossmember. I asked him if they have additional pictures of the tranny installed or how many total cars their shop has installed this in and he said one. The customer’s Dart was the reason they developed the cross member.
He then went into more detail stating the following disclaimers
- all vehicles have variation is the tunnel area
- hammering on the tunnel may be necessary
- grinding on the tranny to releave ribs and protrusions to mitigate interferences
- interferences with the speedometer cable or elections speed sensor will have to be overcome, may require metal work on their bracket depending on the customers parts used to get them to fit
- drive line angles have to be checked and adjusted due to engine cradle and motor mount variations (differences k member vs aftermarket k member QA1)
- warned that there will be several trial fitting several attempts to get the tranny to fit.
- not required but recommended - remove the pinched and spot welded seam above the Bellhousing and motor. They weld the seam 100% solid from the the inside to make the car more ridged and to allow them to remove the seam. At the minimum he recommended bending the seam forward towards the engine bay where the bolts are located to faciataite bolt up.
The moral of the story. They have installed one on a custom build where they has the car 100% stripped down and sold many that have not been returned. This is not a bolt in and go install. Expect tweaking and problem solving to get the tranny in the car. Think ahead or wait to purchase them after you get the tranny installed before purchasing the components you are going to use for the TV lever, gear selector and speedo cable.
I’m going to buy one but I’m going into it with my eye wide open.
Old thread I know, but curious if you still think the swap was worth the sacrifice.
I’ve seen some “post” concerns about removing that much meat from the cross member. And they also comment that the A518 isnt suitable for to much torque. I’m highly interested in this mod for a 360 (400+hp est.) I’m building for my 74 Dart Sport, and think with a few upgrades to the A518, this is a good option. Buttttt, I’m equally concerned about cutting the floor for a tranny that won’t likely withstand the HP and Torque.
Would welcome any feedback and updates on how yours is holding up......
I added some rigidity as well with a full Uscartool kit.I understand you concerns about cutting the crossmemeber. My opinion on the matter is you have to look at the car as a whole and not just localized in that area. You still have the firewall, floor pan and roof structure. The best compensation for removing the center tunnel ware the pictures FABO members posted below. View attachment 1715296074 View attachment 1715296075 View attachment 1715296076
One added subframe connectors and structural driveshaft hoop pictured below. And the other shortened the height of the tunnel channel leaving it entact but shorter. I think both Strategies will help control localized flexing of the sheetmetal in the tunnel to keep the spot welds in that area from tearing. I’m going to do both. This is just my opinion and I’m not engineer.
Like the later of the 2 options. But can see where doing both could really mitigate any negative from pulling out the unwanted material. Surely 3/8th flat bar is as strong or better than the rolled edge being removed in these pictures....I understand you concerns about cutting the crossmemeber. My opinion on the matter is you have to look at the car as a whole and not just localized in that area. You still have the firewall, floor pan and roof structure. The best compensation for removing the center tunnel ware the pictures FABO members posted below.
View attachment 1715296070 View attachment 1715296071 View attachment 1715296072 View attachment 1715296073 View attachment 1715296074 View attachment 1715296075 View attachment 1715296076
That looks really good. Of course I’ve been pondering this all day. As mentioned above, I think the flat bar is likely an upgrade to the cross member......I added some rigidity as well with a full Uscartool kit.
To your point, if I have the skill to take it out, surly I can put it back. Think I will be doing this mod. I think down the road I will be much happier this way especially since it’s a real option. Have both tranny parked on the shelf in the shop......Stress is like water it is dynamic and it changes in conditions a structure is placed in. I know we all only want to fix stuff once but if you have the skills to make this modifications. You have the skills to fix anything that brake or fails afterward. I think any reasonable repair or accommodation is better than nothing. I say use the materials you can acquire locally and since we can’t test it live and learn.
would be great to see some of his "Post Mod" pictures as well....@TrailBeast Also did this swap. He has a warmed over magnum and didn't replace the upper hoop, rather he tied in his sub from connectors to the torsion bar cross member, which is what I plan on doing.
I’ll see will see what I can get done with the sticky. I had the admin combine several posts into a how to.
Your comments got me thinking. We have to remember the tranny crossmember is bolted in and will carry the load. We have to control the amount of slop between the bolt hole and the bolt in the crossmenber. This will reduce localized flexing in the tunnel.
View attachment 1715296583 View attachment 1715296584
I’m now going to install a tube inside the cross member that matches to the OD of the bolt used to mount the cross memeber for the tranny. This will reduce the body flex and leverage the stiffness of the US CAR TOOL crossmember.
