Jessearent
Ha Ha Ha
Ah yes, now I catch your driftWeren't you gonna do a backyard Foundry?
VERY nice gesture! I wouldn't waste your time. When his junk blows, you know who he'll blame...
Can 1wildrt do figuring with a 3.79" stroke crank? Instead of the 4" crank? What's th .135" look like then?After actually doing some recalling in this thread I believe he was recommended to probably sell those and get the right Pistons I mean the creativity in the workarounds are pretty doggone redneck re-engineering science and I dig it, but man if you can get the stuff to work together the first time...
No, YOU, the Assembly Man, have to blueprint and map the build. And I would not even ask someone to do that. That's about like Horseshoes and Hand Grenades brother. Cuz if you're off by a few thousands here and there you'll have a pile of horseshoes left after the hand grenade goes off in itCan 1wildrt do figuring with a 3.79" stroke crank? Instead of the 4" crank? What's th .135" look like then?
Don't have access to any 340 pistons, bummer.Jesse, what 340 pistons do you have/have access to? If you haven't read about what was referred to as the Hoover engine look here... 340 pistons in a 360?
Back in the 70's Tom Hoover use to use 8.5-1 340 pistons in 360's... Apparently you take .030 off the top, chamfer the edge & it may need valve reliefs cut depending on cam selection... There was also mention of possible having to relieve the back side of the pin boss to clear the crankshaft counterweights....
That's allot more involved that just a shave off the top... You probably would be hugely money ahead to track down a set of 360 pistons with a decent compression height...
You need to consider what's happening in the bottom of the engine.... If the piston is being pushed .200 higher then it's also pulled .200 lower, under the piston is the crankshaft.... You don't want those two things to meet....You scared me with the .135" figure. Maybe I need the forged 3.79" crank. Price difference is bout $200. The way I figure, that leaves about .67" that needs to be dealt with. I am figuring just mill that goofy ring that's on top of the stock piston then use the appropriate gasket to put me home at tdc flush with the deck or "close" hallelujah.
Put an add up here in the parts wanted section. You may be able to find one and get Blessed!Anyone with a Discounted forged 3.79" crank for sale would. Be a godsend.
That depends how well you clean up the swarf after cutting the size of the pistons down.What would the compression be around, if the pistons stuck out a little bit....like a stock 340....with 65cc chambers/ also with 70cc chambers. Any one brave a guess....4" stroke crank being used.
Only guys who want to break world speed records cast their own pistons...Weren't you gonna do a backyard Foundry?
Burt Munro did.guys who chase world speed records , absolutly dont run cast pistons !!!
don't bet on itAh finally, I think sanity has prevailed........
that'd do him, i'm sure bearing spacers are available to fit the smaller 340 mains crank into a 360 block. pistons too, that would be doing it properly.I have one with some 4.070 domed pistons. Both used. 340 mains.
Do I smell "Stone Soup"???a ask for a project "donation" would be some gaksets somebody wasn't gonna use and you pick up the shipping. not, like, a fuggin' 340 block my dude.
