Romulo Roderiques
Are you talking about the heat crossover in the middle? 2176 should work. I have used 273 intakes on 318's and 318 aftermarket intakes on 273's. Never a problem. Do you have to use a 1/2 inch wrench on the 273 intake bolts?
I'm at work so can't check at the moment on bolts but yes I'm talking about the heat crossover not matching.
