Valve seals tore on break in
I used those same seals on my slant 6 head and I still have a LOT of room between the guides and retainers. You probably weren't thinkin about a slant 6, though. lol
BUT, I did use 318 valves for some valve spring. They are .300" longer than slant 6 valves.
Lol, no I have yet to do anything on a slant six at work, I guess they just don't wear out like the Chevy crap
Just talked to the machine shop. They’ll disassemble, cut the valve guides down, install new seals, reassemble. Now I just have to find some different seals to use. Any recommendation recommendations? I would want to go more narrow than the current ones for more clearance.
I would be tempted to see what machine shop recommends? They are doing all the headwork anyway?
PS, I am using seals very similar to yours, they may be the same. Mine are Qualcast?? Zero issues(400 miles) on a high lift 340 with dbl springs.
I machined down my X head valve guides and spring pads tho, with help from @Max1196
Good luck
And just FYI. I've installed seals of that nature with an appropriately sized socket for over 35 years and never had an issue.
This is a BB 452 head.
The guide on the right is how the intakes are on these heads.
The one on the left is how both are on most castings.
When I’m cutting the guide bosses for seals/retainer clearance on 452’s I start out by removing the big base and making it like the exhaust.
Then cutting the OD of the upper part down to facilitate the use of a smaller OD seal, and shortening the height at the same time.
I had the intake seat cut down but not the height. Glad I caught it
There is NOTHING wrong with those seals!
When installed correctly they work EVERY time. And the garter spring? It is a great idea because as the seal wears, it keeps tension on the stem to prevent oil use.
[1] You need to pre-oil the stem & seal [ not WD40, it dries out quickly ]
[2] You need the installation sleeve that fits over the stem; this prevents tearing the sleeve during assy.
[3] You need something that fits over the outer edge of the seal to tap it in place without damaging it &/or separating it into two parts. I made a special tool for this.
I always take the spring off to install them. then put the spring back on. It’s easily damaged so why take to chance as it only takes a second to do it the way I do.
I don’t even run that spring on the exhaust valves.
I’m excitedly curious to find my smoking issue when I tear these heads off this winter. They were used damaged Edelbrock I bought for 350.00, repaired them, and ported them. They have been on 4-5 engines since 2008 and although it ran 6.00 last time out has been smoking all year. This engine if you remember was flooded with oil 2-3 times when I built it with those offset rocker heads. I shocked I didn’t take out the rings but it ran 6.07 on its very first pass. So I’m guessing valve guides as they have never been touched. Only smokes ideling and in the water box.
Used to be you didn't see seals at ALL on exhaust valves. Look at the early Hemis. The top of the exhaust valve points DOWN. Oil doesn't run uphill. lol
