Exactly. Simple plan, always easy on the pockets with good results.If I wanted something that mild, I'd just build a stone stock 360. Put a good timing set in it and degree the cam, mill the heads to get compression up around 9:1, put a good loose ignition curve in it and call it done. Tire melter.
Exactlyi had a 360 the previous owner had built to mimic the little red express engine. same cam,wind age tray etc. it ran well enough in my 74 dart to win a bunch of street races but was mild enough my wife delivered pizza with it. That may be the sort of build you are looking for.
yea the EH1 motor. my old lil red ran nice.. truck dipped into the high 14's. probably move the dart along pretty damn good. i do have a mp 340 cam new in the box here..
I like everyone’s ideas. The OEM cam will have a high vacuum for power brakes but the lower the number on the LSA can tend to reduce vacuum a bit that may not be a thing you like.
Since the KB-107’s will be used, on a OEM deck height, there below deck just a pinch. If they end up at zero deck, with a .039 gasket and a possible 72cc chamber, that’s 9.8-1. Think here!
For a true driver, 8-8.5-1 is great and 9.0-1 should be just fine though I’d keep it a garish low not knowing the exact cam. That’s just me.
Mimicking the LRE engine is a good idea. IIRC, it’s about the same as the passenger car engines that had the HP option. I took one apart and it had the windage tray, double roller timing chain. I couldn’t identify the cam for sure but since the stock timing chain was in there, I’ll have to assume the cam was the stock one which is the same cam and he used in the 340’s.
Joe, IF he was doing this for myself, was Indo nothing more than a stock parts rebuild with the KB-107’s since they’re up for use and a good valve job to keep it inexpensive. Exhaust as you see fit.
What is the plan for intake and carb? What you already have in use? Please list the Hughes cam specs.
