Swinger 340
Install a boat motor.if you Install the rear upside down the engine has to rotate the other direction.
Actually- the rotation doesn't change.
But you may have a vent tube issue, a fill plug issue, and some interesting brake maintenance.i
I was thinking about the pinion.I believe it would on the wheels.
Like the 67 GT, it was a trim package, you could have a /6 and GT.
It does change.Actually- the rotation doesn't change
You will only have one forward gear. 3 in reverse. Would be awesome in a demolition derby car and some 5 series gears!!!I was thinking about the pinion.
Just keep it in R then.
Well I'll be danged!Yes.
This copied from Allpar site.
"...There was a special version of the base coupe: the Road Runner. Yes, the Road Runner moved to the Volaré line this year. Not a separate model, it was a sporty package offering Rallye wheels, E70x14 raised white letter tires, blackout grille and taillight panel, special decal stripes, black interior and heavy duty suspension. A mid-year Road Runner option was the Super Pak, featuring front and rear deck spoilers, rear window louvers and Spitfire Orange with black and yellow stripes as the only color. Popular options included vinyl bucket seats and a manual sun roof. All Volaré engines, 360 and 318 V8s and 225 Slant Six, were available in the Road Runner. A six-cylinder ’Runner? What would have been anathema eight years earlier was reality in fuel crisis times...."
Well, first off, you know there's no such thing as a 1968 Plymouth Volare. Volares were around from 1976 to 1980. So I'd suggest you start by finding a better vin decoder. The only difference between an Aspen hood and a Volare hood is the nameplates and trim on it. The hoods themselves are really the same. The model year of your car will be the sixth digit of the VIN. If it's a Volare the VIN will start with an "H" if it's an Aspen it will start with an "N".Hello vets I'm new here. I recently purchased a supposed 76 roadrunner but it has a Dodge Aspen Hood, 7 1/4 rear end, and the vin comes back as 1968 Plymouth volare... At this point I think I'll have to register it as a custom vehicle with all the mix matched parts. Any help truly identifying this vehicle would be greatly appreciated, thanks in advance
Check again. The fifth digit is the engine. There's no engine coded as a "0". Probably a "C", indicating a 225 slant six.NL29082
A47 is the Sportwagon Available in 1979 and 1980In '79 an A47 is a Youth Utility Package.....whatever that is.....Fun Runner perhaps? A57 should be the Road Runner- R/T package as Super-Cuda stated.
Phew, a legal expert. You'll be a big help.I have paperwork and know all about the law I just had a 25-year sentence nullified for theft by receiving a vehicle valued at over $40,000
Why are you surprised by that? The 7¼" rear end couldn't handle a 360 if you pulled four plug wires.Yes it's garbage, original owner said it had a slant 6, I dropped in a 360 and 727 and it broke the ring and pinion on the first test drive.. Currently installing the 9 1/2 from my scrap ram1500, I don't mind 2 different bolt patterns
It could have any engine offered from the 225-1V to the E58 360-4V.Could a 76 Roadrunner come with a leaning tower of power? 318 or 360, but not a slant six, at least not as far as I know.
RM23, not 32.A 68 Roarrunner VIN will start with-
RM21 or after mid year- RM32
