Basically it's a number set to a standard pressure temp and altitude if I remember correctlyIsn't corrected just a way to compare results across dyno's?
Trust me, they are often bogus. And on purpose for certain shops.They're not bogus they're best case scenario
I don't doubt it.Trust me, they are often bogus. And on purpose for certain shops.
True! But it's a eye opener to see a pull with the correction factor just under 1 percent, and then it reset to 10% for the "hero" pullCorrections for atmospheric conditions are a necessary evil for dyno testing comparisons.
Can you share some head information? I'd like to see the flow numbers at .400", .500", .600" along with the intake valve diameter, throat dia or % and the port length and CC's if possibleThis is another test engine that I built to prove our VR-200 cylinder headsC
I already asked, I understand why he won't show them, probably doesn't want to get into a flow bench battle with the naysayers.I'd like to see the flow numbers
Some things are better left to themselves when it comes to custom work.
No arguments here just wanted to crunch some numbers. All good
