I almost forgot, I promised to track my daily weight for the month and share it. The blue line is the daily measurements and the red dots are my normal weekly weigh-in points.
As I said, too much noise in the daily numbers to really tell progress, but the weekly points make the trend clear.
Thanks!Awesome graphic! You must've taken huge dumps on the 5th and 13th. Keep it up man!
Cool!I told your plan to a friend of mine, and he has already lost some weight in just a couple.of weeks, he's stoked about it!
You and your wife drink almost 9 gallons of milk each week??My wife and I buy that much milk a week. 1%. If it wasn't for milk, I would be at my goal instead of stuck at 204.
Don't let it get you down. I'm still stuck at 204-206. That's still 32 lbs less than when I started. And you are still 71 less!Well, it’s 2 weeks into the month and my weight has been bouncing around like a frog on a hot plate. No surprise, at this time of year it always seems to happen with varying levels of physical activity and constantly changing weather conditions.
It finally started to settle down in the past few days and as of my official weigh-in this morning, I am down another lb.
My weight now is 244 lbs and 71 lbs lost.
I will be surprised if I lose much more than another lb by the end of the month. I was above my normal average loss for the past 2 months so it was bound to happen, just like it has many times before on this journey.
I never let it concern me as long as I am still making progress...and it’s all about long term averages anyway.
Yep, still going!Don't let it get you down. I'm still stuck at 204-206. That's still 32 lbs less than when I started. And you are still 71 less!
My weight loss is back to normal trajectory after last month’s apparent slow down. I figured it would even out...like it always has.
I was 245.2 lbs at the beginning of February and based on my daily calorie difference I should be at around 242.2 lbs today by calculation.
Well, today I got on the scale and I am at 242.4 lbs.
Now at around 73 lbs lost
Still going!
