Ddaddy
I'm changing the World... one pixel at a time!
Thanks! I’m still hard at it...and a long way yet to go.That is fantastic. Congratulations Dave!
But I WILL get there!
Fat on the face makes you 'look' younger. Smoothes the wrinkles but not worth it of course.With about a week to go in the month, I got on the scale today and saw the number 241 lbs for the first time. It was 241.8, but still...a good sign that I can hit 241.0 by the end of the month.
Today is exactly 30 months from when I woke up one morning and decided to go down this path.
What a difference 30 months makes, and I see it every time I look in the mirror. The image below is one month before I started and just yesterday.
Comparison images like these continually re-inspire me to keep going!
Thanks...but you can do it too!Way to go, Dave. That is awesome. It'[s just too hard for me. Screw it. I'll just die early.
If I had to guess, you have probably lost some muscle weight along with a fair bit of water weight. It happens. By the end of next month you will know for sure. I won’t be at all surprised if you gain half of it back...or more.Great job! ,I know you will get into those pants! I thought I would have gained weight with the isolation and all, but for some strange reason I've lost 14 pounds in the last month and don't really know why, I've been less active and haven't changed my eating habits. I hope there's nothing wrong like diabetes setting in on me or something.
The muscle loss is the bad part. Finally broke 200(198) But I can see an older mans bicep, the skin being "not as tight." 39 pounds leaving your frame will do it.If I had to guess, you have probably lost some muscle weight along with a fair bit of water weight. It happens. By the end of next month you will know for sure. I won’t be at all surprised if you gain half of it back...or more.
Still, if weight loss is a goal, then build on it and turn it into a positive beginning!
I completely understand loose skin...try seeing what you look like after losing 76 lbs!The muscle loss is the bad part. Finally broke 200(198) But I can see an older mans bicep, the skin being "not as tight." 39 pounds leaving your frame will do it.
The best part was buying new clothes.I completely understand loose skin...try seeing what you look like after losing 76 lbs!
Honestly though, my weight loss has been slow enough that the loose skin isn’t as bad as I thought it might be. Most of what is loose still has a substantial layer of fat under it making it sag. In places like my neck, forearms and lower legs it has been tightening up quite well and is pretty much like I had never had the extra weight at all.
Like everything else on this journey, shrinking the skin is just a matter of time and perseverance.
I figured by now that my belly skin would be hanging at my knees...but it isn’t.
It is still loose and sagging, but it is tightening up as I go and is now a good 8” above where it was before I started.
Still is!The best part was buying new clothes.
