plumkrazee70
70 Dart was originally an auto, just swapped to a 4 speed.
Hydraulic TOB
RAM steel flywheel
RAM 10.95" 3 finger clutch and PP
Rebuilt A833
I was testing gear operation with the rear end jacked up. As soon as the clutch engaged in any gear (except N) I get this weird clanking noise. It's not consistent tho. I have a hard time figuring out where it's coming from.
Things I observed:
The TOB is kind of noisy, I can hear it spinning (maybe they are supposed to be?)
The rear end pumpkin was moving up and down when the noise happen, but not consistent with the noise. Not sure if the clank is coming from up front and transmitting down to the rear end.
I had a hard time capturing the rear end moving, but the sound is pretty clear. Here is a video.
Hydraulic TOB
RAM steel flywheel
Rebuilt A833
Things I observed:
