The Dart met it's forever home.
So I got that going for me, which is nice.
Is that a Diet Pepsi I see? That stuffs no good for you. LolJust having a blast today...
I'm the beta tester for the Cancer society... 4 litres a day....Is that a Diet Pepsi I see? That stuffs no good for you. Lol
I always clip my throw out bearing onto the fork with the fork in place in the bell housing but you do have to be gentle inserting the input shaft at first and keep an eye on it as you move forward to make sure that you haven't knocked it off the spring. It can be challenging but I've been doing it on my car for 30 years and it's pretty simple now LOL make sure that clutchplate and pilot bushing are all lined up with pilot tool and as the input shaft enters the clutch plate I will wiggle the tail shaft shaft slightly back and forth to help align the splines as it enters the clutch plate.This trans and clutch project is going well. Waiting on my friends shop on the trans. Yesterday I had so much fun removing the over center spring in preparation for when I can install the trans back in the car. That OC spring better never have to go back in the car. Other than that cleaned up a lot of the mess I made with dirty tools and old gasket material all over the floor so I can mess it up again. Should I have the clutch fork and throwout bearing in place when I put the trans back in or should I put the throwout bearing on the trans and put the fork in place once in? What do the pros do?
I know the clips on the TO bearing are very tight and without the trans in place I'm able to get it back on the fork. Lets just say I'm having a crappy day and one of the clips is not on correctly and the trans is in. Am I going to be able to get it back on the fork without removing the trans? I have it all lined up and ready to go. The alignment tool even had splines on it to match the trans and input shaft. I remember doing a clutch on my first car and the alignment tool that came with the clutch was literally a wooden dowel. Thanks for your answers.[/QUOTE]I always clip my throw out bearing onto the fork with the fork in place in the bell housing but you do have to be gentle inserting the input shaft at first and keep an eye on it as you move forward to make sure that you haven't knocked it off the spring. It can be challenging but I've been doing it on my car for 30 years and it's pretty simple now LOL make sure that clutchplate and pilot bushing are all lined up with pilot tool and as the input shaft enters the clutch plate I will wiggle the tail shaft shaft slightly back and forth to help align the splines as it enters the clutch plate.
I have a spare dome light cover if you need one? And you should get a mini disco ball the goes under it. The size of a Christmas bulb. That would be the hot ticket. The kids would love it.Drove it... then a model wanted in the front seat so I snapped some pictures.
Looks good Mike. keep at it , and you'll be driving it by spring !Well I'm actually making some progress now that I have changed direction again! LOL
I decided to quit being a "perfectionist" and just get the car finished and running so I can enjoy what years I have left. I was going to paint it black. Thats not going to happen now. I wanted to get everything just abt perfect. Takes too much time. I'm 75, don't know how many more!
I finished rear hard brake lines and installed new gas tank.
Then today I removed front disc brake setup and am installing my new QA1 front end.
Going to force me to finally get tires as my new disc front requires 15" wheels. I have had 14" on front to roll around.
View attachment 1715649181 View attachment 1715649182 View attachment 1715649183 View attachment 1715649185 View attachment 1715649186 View attachment 1715649187 View attachment 1715649188
my two best friends!
[/QUOTE] yes alignment tool is not much more than a wooden dowel but the correct tool will fit snugly into the throwout bearing and snugly into the clutch disc aligning it properly. I have used makeshift tools and been successful . To answer your question about the throw out spring on the fork if the tranny is installed it's tough if I remember one side can be done but the other side it's too tight against the bell housing to really get in there and fix it, the last thing you want is to compromise or damage the spring because that will cause it to become detached after you get it put back together. Just go slow and continue to check the springs periodically before you bolt anything up. Make sure no linkage is hooked up to the fork and the right fork boot will help support everything as you reinstall the transmissionI know the clips on the TO bearing are very tight and without the trans in place I'm able to get it back on the fork. Lets just say I'm having a crappy day and one of the clips is not on correctly and the trans is in. Am I going to be able to get it back on the fork without removing the trans? I have it all lined up and ready to go. The alignment tool even had splines on it to match the trans and input shaft. I remember doing a clutch on my first car and the alignment tool that came with the clutch was literally a wooden dowel. Thanks for your answers.
It's a old car. Those things weren't invented yet. Oh Boy. Also they were called Cigarette lighters back then. Not charging ports.Haha I have one. It does have a little crack in it from when I was trying to figure out how to turn it on...the little bugger is so fragile. Who would have known you dont press on the dome light to turn it on like normal cars.
I put it back on while she was in the car since she started using the cover as a frisbee...
