diymirage
HP@idle > hondaHP@redline
I got one of those in the shop...its got "plan B" engraved in the head
Someone must know how? A BFH is not probably a good methodOn a split bench seat. How does this chrome lever come off? I don't see a set screw. Any help would be appreciated greatly
It's just pressed on. Takes a bit of pull. Careful not to put any pressure on the plastic cover. They generally break at just under pressure required to pop the piece off.On a split bench seat. How does this chrome lever come off? I don't see a set screw. Any help would be appreciated greatly
Thanks. I'll let you know how it goes today.It's just pressed on. Takes a bit of pull. Careful not to put any pressure on the plastic cover. They generally break at just under pressure required to pop the piece off.
I got it off without breaking it. And you thought it couldn't be done. For a Pizza I'll tell you how. LolThanks. I'll let you know how it goes today.
View attachment 1715662689[/QUOTE ( warning!) not to be used when angry or under the influence of intoxicants
I got it off yesterday. Send me a Pizza and you can have this info too. It will save you money buying new ones. LolDon't force it, get a bigger hammer!
I always say just get a run at it LOLDon't force it, get a bigger hammer!
Now if you had Coil Packs like the Chevy guys do you wouldn't have this problem. Just Sayin.Pulled the 64 D100 440 out of the garage to clean up some junk. Noticed the throttle not opening all the way. The accelerator pedal seems low. Fixed it and now no start. Found some dummy knocked a wire off the ballast resistor. Can't get good help these days
Cool car! Was going to hit the like button then scrolled down. Sucks it got hit!I drug home a unicorn.
A 1966 Canadian Dodge Monaco 383, and most importantly, a four speed car. Never thought I'd get a four speed '66 Dodge in the full size flavor. Allegedly 700 some made for the us, and from what I've been told, this is one of 38 for the Canadian market. I'll take that.
Unfortunately, two hours later this happened.
I turned on what I thought was a solid green arrow, following the car in front of me, and a kid hit the car with a square nose Chevy K10. Dyer inspecting the driver's side panel, I decide it is soft and may need to be replaced be as well. I've sourced panels for both sides previously, looks like I'll be buying them. So this is the new stablemate for the Dart, which I swear I'm going to work on.
You can still like the car.Cool car! Was going to hit the like button then scrolled down. Sucks it got hit!
