When toys were real and so was imagination... to think, my youngest is now almost 33 and preggers. Guess I should clean the thing up.. full of blasting sand.. lol
haven't seen one in 47 years when my 2 year old asked what it was a couple days ago... weird!
as far as the car, I'm waiting on some fuel line fittings. I acquired a stumble when I punch it. Think the 50psi section of fuel line just ahead of the pump is sucking shut at WOT. The fuel pressure gauge drops to 3psi when i open the throttle at idle.
i dont think you are correct there
i had that happen on my duster (the soft line collapsing) but it wouldnt become notable untill the top of 2d, beginning of 3rd, in the 1/4 where the bowls would be dry
remember, the fuel pressure you are seeing is going into the fuel bowls so even if it were to drop to zero, you still need to empty the bowls to run out of fuel
the stumble (in my opinion) would be more likely caused by a bad adjustment or little junk in the carb
Im with ya! Its acting like crud in the 2ndary needle. First thing I went after, since then I've been through my vacuum return line, accelerator pump, float level, control module ground, ballast resistor, distributor cap and rotor. It runs up like a scalded dog for a few seconds and then flattens out. If i keep my foot in it I can stall it. If i let up I can get it back to running ok and give it another go with the same result. To your point though, I can't imagine that I could be emptying a bowl that quickly. plugs look rich around the base but very lean at the electrode. when I throw in the towel, I'll enter a post in SB...
Last night I did the 7.25 to 8.75 swap. It was really easy, hardest part was working through all the damn undercoating someone sprayed.View attachment 1715666170
Today I’m taking the drive shaft in to get shortened. I was stupid and bought a shaft that I thought was correct (according to the charts available), but it’s 3 inches too short! Luckily I have my old long shaft...haha...so I can shorten that guy to the correct length for my car. Cheers everyone!
Yes it is. I never made the switch to the big bolt pattern.Is that a SBP 8 3/4?
Looks like its got the special drums on it
Process of elimination...sounds like you got a handle on it (providing the engine doesn't move under WOT and creates an electrical problem)
Have you tried setting the floats higher, to see if that changes anything?
Are those for me? Dude you're awesome. How can I ever Thank You?I made a dumb mistake... so had to have the wife help me rebleed the brakes... then took my daughter to the school to pick up her school work for the next 2 weeks. Girls jumping on the trampoline now.
I'll set up a table in the garage to sit at to start porting the spare heads this weekend...
The cylinder heads. I thought you were doing those for me? Is she a good cook? You've sparked my interest. LolWait, what are for you? The wife and kids? How about I give you the wife in a trade for your black dart? I keep the kids though, they like me spending money on the car and like going for rides in it. Lol.
Or the cylinder heads? Lol... they are only 1.88/1.60 J-Heads I won't be using them though. Since I'd have to buy 1.88 valves to run them, my X heads have 2.02 valves...
Can I have a few days to think about it? LolShes a great cook!
Do I have to part with my spare 340 block too?
I got a gal who lives on the hill, she won't do it but her sister will...Does she have a cute sister too? That might seal the deal? Lol
ZZ Top. Great song.I got a gal who lives on the hill, she won't do it but her sister will...
Still thinking. Might as well load photos too. Lol
Wife said fair trade... and laughed about the sister comment. Her sister looks like her, but has a bigger rear end. Lol
I'll take the sister
