Drove up to the Kroger and filled up with Rec90 and hammered it all the way and back. Last show of the year this weekend and damn its time to put it away and get started on those Christmas lights!
Better start untangling them now if you want them up by Christmas!Drove up to the Kroger and filled up with Rec90 and hammered it all the way and back. Last show of the year this weekend and damn its time to put it away and get started on those Christmas lights!
Jeff
I’m looking forward to seeing that! I’m planning on putting 295/45/18s on the back of my Duster.Well, temporarily mounted the "K" frame, more like a "C" frame for the RMS front end. It will have to come out again to finish cleaning and paint. Got my ***-whooped by the lower bump stop removal also. Now I have holes to weld too.
Besides I am dying to put it together long enough to put the wheels and tires and see how the stance will be adjustable. I've never seen a 69 Dart with:
18 x 10 rear wheels with 295/45R18 rubber
16 x 7 wheels on the fronts with 205/50R16 rubber
Went to our last car show this year and took home another award, bit foggey this morning with lots of water on the car and thwarted the rain this afternoon.
Best deal is a friend with his 440 duster finally scored an award, it is a “really” nice car that somehow has not got the recognition it deserves!
Anyhow we got two awards the other brands did not! Go Mopar!
You’ve been on this forum for 4 months and you still haven’t learned that...Cleaned up and primed the area where the K frame used to mount. Hung the Alternation cross member and drilled the required bolt holes. Installed hardware, lower tubular control arms and the front coil-overs on both sides. Put upper control arm on passenger side and I took absolutely no pictures.
Guess I need to remember that now huh!
The grease trick also can work to free up a stuck engine.Continued working on the brakes for my '73 Dart Sport. Finally got the pistons out of the calipers....whadda job!!!
Tried everything, including compressed air...yeah, I know...dangerous. Used penetrant oil to try and loosen and lube the internal seal a little.
I almost gave up and was thinking of just ordering new ones from RockAuto, but I decided to give it one more good shot: I loaded up my grease gun with a fresh tube of grease and put a rubber tip on it. Made sure the bleeder was closed, crammed the rubber tip into the threaded hose connection and pumped the grease to her while tightly holding the rubber tip in there....viola!!! The piston moved on out to about the last 1/4" or so. Some gentle taps with a hammer and punch around the outside edges and they were out.
This method cost me about 3/4 of a tube of grease but it was worth it to get em on out.
Pistons looked great and no serious pitting in the cylinders!!! I was pretty concerned since they've been sitting in the shop for over 17 years...LOL
Glass bead-blasted the internals clean, including the seal slots, etc. Washed everything completely spotless with brake cleaner. Made sure the piston fit without the seal first.
All was good and assembled with new seals using a tad of silicone grease for lubricant. Got one completely rebuilt and ready to install on the car. I should have the other one ready to go by lunchtime tomorrow. Getting this old gal back to roller status has been a chore....but I love it.
You're going to need a bigger tube for that trick to work!The grease trick also can work to free up a stuck engine.
It`s not the size of the tube that makes it turn. Take an old spark plug and weld a grease fitting to it then just pump away.You're going to need a bigger tube for that trick to work!
