cjackson3396
Active Member
Yea I planned on pistons..the 360 heads What work should I look at for them...I can port them... what valves and stuff or shouldn't i get into that...
I agree 100% . Was quoted $900 to reguide, plane, install hardened seats, stainless valves, new springs, w some pocket port work on some X heads. RHS may not be all that much more said and done w a smaller chamber and better flow #s. May not be the case depending on cond. of your heads. IMO i would start there.I'd get an estimate on getting the 360 heads gone through and take a hard look at the RHS heads for comparison.
They flow very well and get the combustion chamber sizing you want without all the milling (and the potential for intake mating/head seal hassles).
My 904 is holding up really well to all the abuse I'm throwing at it.
The reason to spend money on a 904 instead of a 727 is that the 727 is MUCH heavier than the 904 (makes you slower), and takes a gob more horsepower to turn (makes you slower). To say nothing of the additional hassles of getting a new driveshaft, etc.
Good luck!
Steve
I can get a set of heads for minimal $$ like 50 bucks...Porting and decking i can get away with but the valve job and seats is where id have to send somewhere....Prolly see if the guy thats boring the block can throw that into the mix too
