What to do...
Mopar Racers Forum
  1. Toluene56
    Toluene56 Well-Known Member
    889
    661
    Nov 9, 2009
    reno
    Local Time:
    4:45 AM
    So I've finally got to hit the track this year.
    Previous best run last year with some issues was 11.70@113 I think around 5800ft da that day.
    After some test passes and playing with timing before I ran out of tnt time.
    11.57@117.8 at 7000ft da
    1.64 60ft
    7.38 @93.6
    Shifting at 7000rpm
    27x10.50 Hoosier 4.30 gears
    4500ish stall converter (not built for the combo)
    Leaving off idle (best 60ft so far)
    Here's the catch.. I think it can go a smidge quicker. I have a feeling a new converter built for the combo would be the ticket. But that's pricey. And aside from putting it and me on a diet, anything else you folks think I could do to eek out a little quicker?
    Here's the combo as it sits
    73 dart, all steel and glass w subframe connectors. 3500lbs (more of a guess but I'm a big boy)
    Magnum 5.9 scat rotating assy 408
    11.75:1 comp
    Trickflow heads
    Super Vic intake (basic port match)
    Qft 950
    Howard's solid roller 257/267@050 .640/.645
    Loose front suspension, qa1 upper and lower control arms and strut rods
    This outing I used drilled out stock shocks, I do have a set of 3way CE shocks to use as well (had the best 60ft with them last year 1.59)
    Caltrac mono leafs rear with rancho 9000 shocks
    Not the best video of the run, but it's what I have
    • Like Like x 1
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      2,730
      2143
      Jan 1, 2018
      Southwest VA
      Local Time:
      7:45 AM
      That's some serious altitude your running at. Many racers that race consistently at over 5000 feet carry a little extra atmosphere in a big blue bottle. Nano makes a really good capped nitrous system that maintains bottle pressure through a run without any bottle heaters and the like. A 50 hp shot with one gives gains closer to a 75 shot with the consistent nitrous pressure.
      • Like Like x 1
      • Agree Agree x 1
      • TT5.9mag
        TT5.9mag Two atmospheres are better than one
        347
        351
        May 5, 2016
        So cal
        Local Time:
        4:45 AM
        1.good set of adjustable rear shocks. Spend the money, they’re worth it.
        2. Better front shocks. Not as important as rears but still worth it.
        I would contact Calvert with some specs and ask they’re recomendation.
        Tune tune tune on the suspension. It seems you’ve got the engine pretty dialed just need to get the chassis to follow suit. Love your car been following it on here for a while.
        • Like Like x 1
        • Agree Agree x 1
        • TT5.9mag
          347
          351
          May 5, 2016
          So cal
          Local Time:
          4:45 AM
          One more thing you probably know already, diet. Lightning the car up is the best and easiest way to make it faster.
          • Agree Agree x 3
          • Like Like x 1
          • Toluene56
            889
            661
            Nov 9, 2009
            reno
            Local Time:
            4:45 AM
            Rings are gapped for nitrous (250+ according to the specs from icon when I gapped them)... I just wanted to see how far I can take it before adding it.
            • Like Like x 2
            • Toluene56
              889
              661
              Nov 9, 2009
              reno
              Local Time:
              4:45 AM
              The plan is for da shocks front and rear eventually, they're expensive though. Of course I could always do rears first and stick with the cheap 3 ways up front for a while.
            • Blind Squirrel
              Blind Squirrel Well-Known Member
              790
              601
              Oct 1, 2015
              Pacific NW
              Local Time:
              6:45 AM
              You say your leaving off at idle?
            • Toluene56
              889
              661
              Nov 9, 2009
              reno
              Local Time:
              4:45 AM
              Yea, seems to have the best 60ft. Idle is about 950-1050rpm
              • Like Like x 1
              • Blind Squirrel
                790
                601
                Oct 1, 2015
                Pacific NW
                Local Time:
                6:45 AM
                I missed what rear end gear your running. If I hit my tires off idle with my 4500 stall. I'd still be spinning. But I run 4.58 gears.
                Never mind. found it. 4.30' my reading comprehension skills sometimes sucks
                • Like Like x 2
                • Toluene56
                  889
                  661
                  Nov 9, 2009
                  reno
                  Local Time:
                  4:45 AM
                  Usually that is the case, but this test n tune they actually prepped the track for nhra national open qualifiers. So it hooked well.
                • Garrett Ellison
                  2,730
                  2143
                  Jan 1, 2018
                  Southwest VA
                  Local Time:
                  7:45 AM
                  I'm assuming 727 with standard gearing? What RPM are you going through the traps at?
                • PRH
                  PRH Well-Known Member
                  2,289
                  3485
                  Dec 14, 2018
                  So. Burlington, Vt
                  Local Time:
                  7:45 AM
                  I’d look for a used Victor.
                  I think the SV is too big for that stall
                  speed and elevation.
                  The speed is good enough for a few tenths better ET, but the 60’ isn’t there.
                  • Agree Agree x 3
                  • Garrett Ellison
                    2,730
                    2143
                    Jan 1, 2018
                    Southwest VA
                    Local Time:
                    7:45 AM
                    Used Victor or Holley Strip Dominator along with tuning the suspension. The gearing calculator shows that a 4.88 gear would really make it come to life, but if your going to spray it I probably wouldn't go lower than a 4.56. Extra gears before getting the bite right would probably do nothing except to make the car go slower, though!
                  • Toluene56
                    889
                    661
                    Nov 9, 2009
                    reno
                    Local Time:
                    4:45 AM
                    Knew I forgot something..
                    904 w low first
                    About 6900-7000 through the traps with the 27" tire
                    • Thanks! Thanks! x 1
                    • Toluene56
                      889
                      661
                      Nov 9, 2009
                      reno
                      Local Time:
                      4:45 AM
                      I wonder if the trickflow intake would be any better...or maybe a ported air gap intake?.
                      I would think the air gap would help the low end but then Peter out up top.
                      • Agree Agree x 1
                      • TT5.9mag
                        347
                        351
                        May 5, 2016
                        So cal
                        Local Time:
                        4:45 AM
                        A dual plane would be a step backwards with a 4500 stall and that cam. If this were my car I would put more converter in it, a good set of rear adjustable shocks, and start thinking about a trans brake. Get it to leave on the converter and hook and it will ET better. Where is peak torque? Have you had it on a dyno?
                        • Agree Agree x 3
                        • Toluene56
                          889
                          661
                          Nov 9, 2009
                          reno
                          Local Time:
                          4:45 AM
                          I figured it was a step backwards.. no dyno.. converter is planned.. mainly because I want one that will handle nitrous. But I will say it feels like it will pull Past 7000rpm.. I just ran out of time to up the rpm in increments. Plus 7k + makes me nervous lol
                          • Like Like x 1
                          • Garrett Ellison
                            2,730
                            2143
                            Jan 1, 2018
                            Southwest VA
                            Local Time:
                            7:45 AM
                            If it feels like it will keep pulling to 7500 and you modified the oiling system to keep up with it, then I would try a 4.56 gear (may seem small, but drops close 15 mph off your shift points. The base Victor 340 is probably the best manifold to get unless you want to get a strip dominator or an MP single plane and fill the carburetor pad in from a spread bore to a square bore pattern. The trick flow looks a whole lot like the super victor to me. It’s a little more “Street“ than “Strip“, but I sorta like an old Weiand 7510, too. Basically a large plenum accelerator. They’re almost impossible to find now, but I’ve known of a few fast drag cars that have used one.
                          • TT5.9mag
                            347
                            351
                            May 5, 2016
                            So cal
                            Local Time:
                            4:45 AM
                            @Garrett Ellison do you think he should change gearing with the future plans of adding nitrous? Im not a nitrous guru but my first thought is no. Stick with the 4:30 and try it. I’m under the impression that the nitrous combo will want a lower gear. But I’ve never gone really fast on gas.
                            • Agree Agree x 1
                            • abdywgn
                              abdywgn dismantler
                              1,368
                              658
                              Jul 30, 2006
                              Darien, Illinois
                              Local Time:
                              6:45 AM
                              short shift first gear?
                            • mini
                              mini Small Bore Long Stroke
                              474
                              257
                              Jun 1, 2009
                              Chatham Ontario
                              Local Time:
                              6:45 AM
                              For the altitude I think you are fine. Wallace says at 1200ft that time should be around 10.6 10.7
                              • Like Like x 1
                              • Garrett Ellison
                                2,730
                                2143
                                Jan 1, 2018
                                Southwest VA
                                Local Time:
                                7:45 AM
                                Correct! I think suspension tuning and a nitrous specific converter that the extra cylinder pressure won't "blow through" is the next step if that is the intention for the car. A nitrous specific converter usually has to be tight enough that it won't stall effectively for running naturally aspirated. If the 4500 rpm stall converter has anti ballooning plates and is acting tight, I'd get the suspension ready and put a system on it. I'd probably keep the SV intake, too, the torque it leaves off the line may make the hit a little softer when the spray comes in.
                              • Toluene56
                                889
                                661
                                Nov 9, 2009
                                reno
                                Local Time:
                                4:45 AM
                                That was my original thought with the sv and nitrous... Although I'm not sure the converter has antibalooning plates in it. I didn't really wanna take the chance with a large hit.
                              • Garrett Ellison
                                2,730
                                2143
                                Jan 1, 2018
                                Southwest VA
                                Local Time:
                                7:45 AM
                                Definitely not, Lol! What's the converter diameter and brand? Many of the nine inch or smaller converters have an anti-ballooning as standard equipment.
                              • Toluene56
                                889
                                661
                                Nov 9, 2009
                                reno
                                Local Time:
                                4:45 AM
                                I believe it is a 9" dynamic.. made about 12 ish years ago..was never used and came with another car. So I used it in mine. Lol
