Anyone know where Teeth and Tires went to? Anyone see him lately?
That looks like the kind of place where they could put up chicken wire before the show if they thought it was necessary.
Don’t you remember?Anyone know where Teeth and Tires went to? Anyone see him lately?
Thanks Dave. No I didn't remember that.
It was a sad day when I learned of it. Sometimes forgetting is less painful than remembering.Thanks Dave. No I didn't remember that.
When the blood warms, sometimes you just gotta Rock!
Def Lizard...Or is it ”Lizard Skyner”?
I'm very sad to find this out, I missed it and hadn't found out until today.
Cool pick guard, did you modify it yourself?My latest is a modified Epiphone Les Paul SL.View attachment 1715672493
I found one of those in a trash can in the 80s.
I bought it in December. Used at a Local music shop. Did not try or play it stock. It had strat like single coils and black strat type knobs. Bought it and a set of extra slinky strings. When I got home I immediately removed the strings and cut the pickguard for a set of Mini Humbuckers ( body was routed enough stock) and gold mounting rings, changed the knobs and added a Rhythm/Treble Selector Switch ring, parts I had laying around. Painted block markers over dots. Installed new strings. Intonation was close enough. Sounded good , but then changed Volume pot to a 500k linear taper that had better response . My band liked the sound at rehearsal. A little tri-flow on the nut and bridge. Stays in tune. I will be using it at Bar gig this Saturday (unless Covid-crap cancels it).Cool pick guard, did you modify it yourself?
Cool, I didn't realize they were mini humbucker's at first, I thought they were P90's , I like the mini humbucker's, that made a really neat guitar.I bought it in December. Used at a Local music shop. Did not try or play it stock. It had strat like single coils and black strat type knobs. Bought it and a set of extra slinky strings. When I got home I immediately removed the strings and cut the pickguard for a set of Mini Humbuckers ( body was routed enough stock) and gold mounting rings, changed the knobs and added a Rhythm/Treble Selector Switch ring, parts I had laying around. Painted block markers over dots. Installed new strings. Intonation was close enough. Sounded good , but then changed Volume pot to a 500k linear taper that had better response . My band liked the sound at rehearsal. A little tri-flow on the nut and bridge. Stays in tune. I will be using it at Bar gig this Saturday (unless Covid-crap cancels it).
That's cool, don't see a lipstick pickup in a strat very often, the floyd rose is cool! Or is that a different pick up, with the glare on the chrome I cant hardly tell.
My first electric guitar was a silvertone amp in case, I bought it from my cousin in 1974, I sure wish I had kept it for nostalgia's sake.^^^
It is just the glare.
I'm a bit of a kramer fanatic.
Those are all kramers.
I had the pick guards made by a guy in Florida.
Quickgards is the guy.
The pickups are custom shop Dimarzios in the one.
They have chrome covers .
However I do have my dads first guitar.
A Dan Electro Silverstone with a lipstick pickup.
Has the case that is an amp as well.
