You need exhaust manifolds from a magnum pickup truck.I'm interested....what manifolds do I need to start looking for? Currently the car has TTI headers and a 340 ....and how much will the kit cost in Canadian dollars .....JK
Yes you can use the a body driver manifold, but they are very hard to come by. My kit does work with power steering...
great news, just about to start working on my sons demon, this is looking like a great way to go on it!Oh yeah, still going on...just waiting for spring here in Michigan to start testing.
Khalid ,he's on YouTube,under the same avatar handle....Good stuff.My 360 recently took a dump and I have a roller-cam 318 LA coming down the line (along with the original non-roller 318 I took out of my '70 Duster) so a turbo build is now a much closer reality...
Dizuster, I have see your 360 Turbo Savoy on Youtube. Awesome car, but i have not seen much on your engine combination.Oh yeah, still going on...just waiting for spring here in Michigan to start testing.
Any idea if the kit will work in an early A body?Oh yeah, still going on...just waiting for spring here in Michigan to start testing.
Its spring already, what happens?
I've given up on it.It would be nice to get an update!
I think these guys are from Michigan.
But if their weather is anything like Ohio's weather, It Seems like it's Raining Every Stinking Day.
I'm sure their test time is limited.
Dunno about Turbo, but I was recently checking out Paxton superchargers for Carbed Small Block Mopar...
Are you running a hydraulic roller cam or flat tappet cam and what lift and lobe separation and are the heads ported? I have a Plymouth Roadrunner and having a problem finding a decent 440 block. But i have a .60 over 318 and the idea of turbocharging it fascinates me.
Hardest part is the hot section. And the alternator relocate is fun. I'd imagine a hot section kit wouldn't take much time after the first design to build in bulk. If I could do it over I wouldn't have gone with stainless exhaust. Too many flex bellows, purging pipe with argon, worry about cracking pipes. Mild steel and magnum truck manifolds is the way to go. It's going to be wrapped anyway. The downpipe from the turbo is a hard part to make for sale without providing a turbo and a wastegate so flex joints are a must and fitment is complicated with a 3" pipe between the trans and firewall.
