txstang84
He's said about 4 times on this thread he won't estimate or release a price until all the testing's done...
thanks txstang glad you can count , never hurts to ask since there hadnt been an update since september
My personal motor has a 1/2 filled girdle block, with head and main studs. The test motor for these kits will be a 100% stock bottom end, stock replacement head gaskets, and no studs. The idea is to prove out what a STOCK motor can withstand... modified motors will obviously take more power depending on the parts.
No prices yet until kits are proven out, and tooling is completed. I have an idea, but until testing is completed I don't want to say much...
thanks txstang glad you can count , never hurts to ask since there hadnt been an update since september until last weekend
You've taken your time and it looks pretty good. At least you've kept in touch and kept everybody updated. That turbo is pretty big. Nice lookin work.
thanks to you to rustyratrod, glad your still your jolly old self as you always are in your posts
Dunno if anyone actually took the time to watch a couple of his other youtube vids...
Of course it's difficult to tell, but looks like it's moving along pretty well to me.
Just wanted to start getting the word out that I'm in the process of engineering/testing/quoting mopar turbo kits right now.
The kit will be based on magnum manifolds (read CHEAP), 2" stainless hotside, 3" stainless downpipe, 44mm gate, 50mm BOV, and various T4 turbo options. All tubes will be production mandrel bent, and TIG welded on assembly fixtures to ensure dimensional repeatability and quality.
The mock up layout I have right now fits A-B-E bodies... I will verify on FJM bodies soon, and should fit trucks also. Ordered parts today to build the first working test prototype, so as long as all goes well, these should be ready fairly soon. My 62' Savoy will probably be the test mule, so I'll be replacing my Eddy headed 360 S475 setup with my own kit. These kits will NOT require any MAJOR modifications to your car... only slight trimming on a few select cars if anything at all.
The magnum manifolds do NOT clear a factory A-body power steering boxes, so PS will be out. I didn't want to create a kit based on old A-body manifolds that are hard to come by compared to the magnum stuff. AC does look like it will fit though. These will be offered with various T4 turbos, both with and without intercoolers (intercooled kits will require cold side clearance holes).
Initial quotes coming back show that this should be affordable compared to the alternative boost options we have out there (prochargers, paxton's, roots, etc...)
Hope this helps get the mopar community going on the turbo technology. If the Ford and Chevy guys can do this... so can we!!!
I will not be casting any new small block manifolds because there are in abundance. Future BB kits might be another story though. But we'll see how the SB kits go.
I just went back through the thread again...do you think a set of the C body log style manifolds would work in a BB application?
The best way to use oem mag manifolds is to find a drivers rear exit and a pass. front exit, passing the cross pipe aft instead of forward. This way you can retain power steering box and column, easily.
Its been a long time since i looked at it, but im 99% sure the magnum manifold even in the correct intended mounting location does not clear the factory a body power steering box.
Also there is very little room for the down pipe, and the cross over on the pass side if you do it this way.
Maybe, but then you'd just use any oem drivers manifold in stock orientation. folks have run a cross pipe under the pan easily. Just saying, there's profit to be had if you can retain power steering.
