SRT_DSTRHOLC
Are you doing any kits for the slant 6?
or v8
dizuster,
If I may impose ....your choice of C.A.C. & mounting location ???
--- or is the kit low boost, < 6 psi which 'hypothetically' would not
need charge air cooling.---
Thx!
mech1
Pretty sure he uses e85. e85 has way more cooling effect then pump premium and other fuels.
mech1nxh said:dizuster,
Thx!
mech1
this is the turbo setup on my personal car... The kits will be slightly different then this (less complicated). Cast crank, stock 360 block, 230@.050" cam, on 15~16psi has been 9.80's at 3740lbs. These turbo's are the real deal...
[/url]img_20140723_183648_773 by [/img]
Suscribed. Interested in a simple intercooled single turbo setup, at a lower horsepower setup.
What is your realistic time line with releasing a kit? Were waiting. If possible could you PM me a rough idea of where these kits are going to be priced.
Are you going to address or recommdations on:
Head gaskets at different power levels
Head bolts vs studs
Fuel line size
electric vs manual fuel pump
Heres a nice clean engine bay to put one in...
