3404spdfish
I always was told that carbs work on negative pressure and whats the get past info for a positively charged carb since the motor is fed by turbo. just wondering thanks
This is the turbo setup on my personal car... the kits will be slightly different then this (less complicated). Cast crank, stock 360 block, 230@.050" cam, on 15~16psi has been 9.80's at 3740lbs. These turbo's are the real deal...
[/url]IMG_20140723_183648_773 by [/IMG]
X2 ... That's a nice , simple setup.Is there an option for a setup like yours?
Can I have some of that carmel stuff and extra butter?:happy1:
The problem with my current setup pictured above is that it requires the radiator to move. Notice it's on the front side of the core support. That isn't possible on all body styles.
Did not even notice that lolz what about twins and mad darts setup
I'm still eagerly watching this thread.. My younger brother just finished turboing his 2332 Vw bug (he spent a ton of money having someone fabricate everything) and I would love to show him what's up with a good basic setup on a pretty much stock 318. I would also like to get rid of my cheap low-hanging headers, this a great solution for that! :sign3:
