I'm most definitely working on this. I'm hoping to finish up the turbo locating/mounting bracket tomorrow. Everything is really coming together nicely with these.
Couple of updates for you guys... I can confirm that:
-There WILL be power steering and non-power steering kits available
-The ONLY cutting to the car body anyone will have to do is a small 1/4" grind on the inner frame rail lip to clear the stock magnum manifolds. Other then that, no other inner fender, firewall, core support, etc... cutting is required.
-You will be able to put this kit on with hand tools. No welding, machining, cutting, etc... required.
-You will not have to relocate your battery.
-You will be able to re-use your stock alternator.
-The kits will fit A,B, and E bodies. F/M are still up in the air because of the transverse torsion bars.
-I will be proving out the basic kit on a dead stock 5.2L magnum motor to show you guys what it will do on a budget.
-I will prove out the higher HP kit on my built 360 to show what you can do with a decent build.
No pics yet because the turbo is still moving around slightly, so I'd like to wait until I get the final location/layout completed before sharing... but stay tuned... they will be coming!!!
