X & H pipe vs straight dual exhaust
Mopar Exhaust Systems
  1. rod7515
    rod7515 Well-Known Member
    1,612
    475
    Jul 18, 2013
    Red Lion PA
    Local Time:
    5:00 PM
    When looking at exhaust I see a lot of x-pipes and h-pipes and was wondering what advantage this gives you if any or is it just a sound changer. I have always just gone straight back to a muffler. I will be using TTI headers and will be running on the street about 1500 miles a year. They sell both x & h pipes that will fit on my 66 dart but it's an expensive option! Has anyone gone from a straight exhaust to one of these pipes and seen a big difference?
    Thanks
    Rodney
  2. doug 371
    doug 371 Well-Known Member
    2,118
    335
    May 29, 2004
    Regina, SK CANADA
    Local Time:
    10:00 PM
    tti claims there x pipe makes 15 hp over the h pipe
  3. siuauto
    siuauto Well-Known Member
    385
    65
    Jan 9, 2008
    Joliet Illinois
    Local Time:
    4:00 PM
    Great topic
  4. goldduster318
    goldduster318 Overzealous Car Modifier
    1,741
    302
    Aug 25, 2007
    Lake Orion, MI
    Local Time:
    5:00 PM
    I bought the summit x-pipe kit and made my own x-pipe. Since the TTIs don't come out straight, I had to buy some 30 degree mandrel bends, but other than that it wasn't too difficult. I welded mine together.
    I used to have just plain duals but I changed my engine at the same time. I do have to say, the x-pipe is significantly quieter.
    [​IMG]
  5. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    69,165
    43647
    Jun 7, 2010
    Georgia
    Local Time:
    5:00 PM
    I never have liked the sound any type cross over produces. It takes away some of the crispness of the exhaust note. I guess if you're going for every ounce of power on the track, then great, but you'll never feel 15 HP on the street.
  6. SpikeWills69
    SpikeWills69 Too Soon Old, Too Late Smart
    1,620
    162
    Apr 7, 2010
    Near ZMax Dragway
    Local Time:
    5:00 PM
    So Rusty, I often complain when I hear high performance cars that, as I describe it, sound like the exhaust is coming through a 55 gallon drum. I have always blamed it on a lot of the newer muffler designs, but is this what you are talking about? So is my criticism misdirected? Is it really the crossovers instead?
  7. 340 8BBL
    340 8BBL Well-Known Member
    708
    3
    May 19, 2009
    in the woods
    Local Time:
    2:00 PM
    on my setup an x-pipe made a noticeable difference in both sound and low end torque.top end felt the same,X,H,or true dual.but the x-pipe produced the best low end.the exhaust note also got smoother and quieter.
  8. 66340SEDAN
    66340SEDAN FABO Member #3649 FABO Gold Member
    29,182
    38809
    Nov 20, 2006
    Minnesota
    Local Time:
    4:00 PM
    Many Mopar muscle cars came factory stock with an H-pipe and they all sound great IMO.....I have a Heddman Header X-pipe on my 340 in my 74 Satellite with Flowmasters and love it, it sounds so sexy and mean, always get compliments on it....click on the picture to play the video :-D
    [ame=http://i220.photobucket.com/albums/dd134/66340sedan/MOV05101.mp4][​IMG][/ame]
  9. superchargeddrt
    superchargeddrt Well-Known Member
    2,331
    896
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    5:00 PM
    I had a H pipe put on my car in 1988. It's still on there and I see very little difference in times at the track between open exhaust and through the mufflers. All I can say is that they appear to work.
  10. davescuda
    davescuda FABO Gold Member FABO Gold Member
    10,347
    1711
    Apr 30, 2007
    Cheshire, CT
    Local Time:
    5:00 PM
    H pipe makes more power than straight or X
  11. rklein383
    rklein383 Well-Known Member
    1,606
    528
    Dec 2, 2005
    Local Time:
    4:00 PM
    When I did my x-pipe kit from Summit, I put flanges before the mufflers, that way I can unbolt the entire exhaust under the car and still leave the mufflers and tailpipes hanging. I can easily do a clutch change or whatever without the exhaust being in the way.
  12. JGC403
    JGC403 Well-Known Member
    1,025
    43
    Nov 22, 2010
    Baileyton, TN
    Local Time:
    4:00 PM
    I thought a lot of Mopars came from the factory with H-pipes. It increased low end torque. The factory wouldn't of added it if it didn't do something.
    I think there is a lot of opinions on H vs X pipe if one makes more power than the other. Since the location in the exhaust system matters and it could of been placed in the wrong location and therefore wouldn't feel any difference in power. From what I understand is that an H-pipe should be placed right behind the header collector. An X-pipe should be about half between the header collector and the exhaust tip.
    That setup is going to be restrictive. The exhaust is only going to flow as much as the most restrictive area. There are 2, what looks to be 3" pipe, merging into the X-pipe that is only the diameter of 1 pipe at the middle of the X.
  13. BrianT
    BrianT Let's go!
    5,521
    1258
    Mar 13, 2007
    Kansas City, Mo
    Local Time:
    4:00 PM
    Subscribed.
    I have TTI's and custom built mufflers and need to figure out what we are going to do to connect them.
  14. Locomotion
    Locomotion Well-Known Member
    3,076
    603
    May 31, 2004
    Florida
    Local Time:
    5:00 PM
    I went from open exhaust with collector extensions to a TTI X-pipe ending with Dynomax UltraFlo mufflers just in front of the rear axle and the car went faster by between .05 and .10. Headers are TTI 1 5/8"-1 3/4" step on a 360. May require minor rejetting.
    It added an extra 60+ lbs to the car, but I removed the weight from other locations to bring it back down to what it was. You shouldn't have to worry about it since you plan on a full exhaust anyway. Room to swap out center sections is limited, but worth it. I plan on using their bullet style mufflers next time to save room and weight, although it may be a bit louder.
    To me, X-pipe looks more effective than an H-pipe because not only does it help equalize the pressure between the two sides, but the flow from one side can help scavenge from the opposite side at the X as well.
  15. famous bob
    famous bob mopar misfit
    18,851
    8088
    Aug 14, 2011
    okla
    Local Time:
    4:00 PM
    :blob:eek:nce upon a time , I bought the complete drivetrain out of a 68 hemi roadrunner, had 11,000 some on it when it rolled. it had a factory h pipe on it. don` figure it was for low end torque, cause the hemi had more than u could use back then anyway-----just sayin-bob
  16. Locomotion
    3,076
    603
    May 31, 2004
    Florida
    Local Time:
    5:00 PM
    I can't confirm it, but it makes sense...I heard H-pipes were used on production cars because X pipes created bigger clearance and maintenance issues on the car overall. So they compromised with an H.
  17. TrailBeast
    TrailBeast AKA Mopars4us on Youtube
    21,488
    9166
    Mar 11, 2011
    Arizona
    Local Time:
    3:00 PM
    The X is better for scavenging at higher RPM's, and ANY type crossover from one side of the exhaust to the other is going to quiet down the exhaust by partially canceling out the harmonics created by each cylinder firing down a single pipe.
    I did a crapload of reading on the differences before I did my 2.5 inch X system.
    And as said above, it does create a different sounding exhaust.
  18. Lelo Dart
    Lelo Dart * FABO Gold Member
    1,480
    435
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    4:00 PM
  19. DFX 340 Duster
    DFX 340 Duster FABO Gold Member FABO Gold Member
    1,785
    630
    May 14, 2009
    Orange County CA
    Local Time:
    2:00 PM
    I had a 426 Max Wedge with the Ramcharger exhaust system. It had an H pipe after the large cut outs exiting under the doors. Man, I miss that car.
  20. 1Fast340
    1Fast340 Well-Known Member
    1,189
    401
    Dec 30, 2011
    Sweden
    Local Time:
    11:00 PM
  21. Vitamin c
    Vitamin c Vitamin c FABO Gold Member
    1,276
    38
    Dec 1, 2009
    Holland, MI
    Local Time:
    5:00 PM
    My latest purchase is a 71 R/T charger with aftermarket exhaust. Friday I ordered a complete stock system from tom swope and had a discussion on what was correct for that car. Originally a 440-4bbl car with no tips and turn downs. The car has been switched to a six pack setup, which made my decision to upgrade the new exhaust to the six pack/Hemi style with the rear resonators and tips. Tom had indicated that the six pack cars did not have an H pipe installed per the blue prints. He indicated some may have made it out with an H-pipe, I ordered it without.
  22. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    18,201
    5817
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    4:00 PM
    ...............I have had A,B,C and E bodies and not 1 had a H pipe factory, ofcourse I never had a HEMI car..........I do like the sound with the H pipe thou..............kim.....
  23. grimreaper
    grimreaper Cross Member
    3,629
    812
    Jul 8, 2005
    Gillette, WY
    Local Time:
    3:00 PM
    I had independent 2-1/2 pipes on my gold Barracuda when I put the 360 in it. I just hooked them up to my Spitfires. The exhaust note seemed a little sharp to me so I added an H-pipe. Torque went noticeably up and exhaust noise went noticeably down. Top end didn't seem to change. About a year after I did that a friend gave me a new 2-1/2 exhaust with Borla mufflers he pulled from his Mustang. I swapped just the mufflers to begin with and the exhaust note was mellowed but louder with no other noticeable change. One day I cut up what was left of the Mustang exhaust and welded it, along with the X, to fit the Barracuda. The difference that made was a quieter and more mellow sound and new pipe. My observation would be that the H or X pipe are almost equal improvements over the independent pipes in that they add torque and soften the exhaust noise. I don't think that is anything new, just a personal confirmation.
  24. BrianT
    BrianT Let's go!
    5,521
    1258
    Mar 13, 2007
    Kansas City, Mo
    Local Time:
    4:00 PM
    Why don't you save us the trouble of buying them and finding out that they are no good by telling us EXACTLY what the problem is with them and how you know?!?!
  25. goldduster318
    1,741
    302
    Aug 25, 2007
    Lake Orion, MI
    Local Time:
    5:00 PM
    The pipe is 2.5", then at the X its 3 1/2" wide by 2.5" tall in an oval shape. So, its about 7.5 sq in area vs a 2.5" pipe of 4.9 sq in. Theoretically, there shouldn't even be exhaust pulses hitting the X at the same time, so chances are it's not really restricting anything. Most X pipes I've seen are a bit smaller than 2 pipe diameters at the X.
    I would imagine that this would actually help the scavenging effect, which is why you use an X pipe to begin with.
    I have mufflers that resemble the AAR cuda mufflers (they are Dynomax Super Turbo), so the entire exhaust will drop off as one big piece if you have to do any work on the transmission.
