Well, I wasn't taking sides pertaining to Dougs vs TTI's, and I stated it was "simple" not "easy". You can get it right the 1st time if You're patient, and as stated some spotsIt's a tight fit and the tolerances on these cars are like +/- 1/4". On some cars there's no hammering and tweaking, on others there are. If I ran stock torsion bars with an automatic transmission on my car there would have been no dimpling or tweaking at at all with the Doug's. But I run 1.12" bars with a 4 speed and use a milodon road race pan, so, my options were limited to adding some small dimples for my torsion bars.
I'm using stock spool mounts with polyurethane replacement inserts. I have a V8 spool K frame. I haven't taken a survey or anything, but it seems to me that folks that run spool mount K's seem to have better luck with Doug's compared to TTI's. I'm sure there are exceptions, because with the factory tolerances these cars had there will always be exceptions.
I love the Doug's on my car, I wouldn't buy TTI's again. Just not very impressive for the price, the coating looked like cheap aluminum spray paint. You can get the Doug's from Autozone sometimes with a 20% online discount that they run.
Yeah, ok. And everytime you adjust the depth of the slot you're going to have to pull the engine and headers or drop the K frame while supporting the engine to either get in there with a MIG or a grinder (or both). And you won't get it right the first time, so, you're going to do that a couple of times. Yes, sure, I see your point there are ways to adjust the engine height with the spool mounts. But that's not anywhere near the same league of modification as adding a shim or two under the biscuit mounts. And on my car at least there's nothing that a 1/4" up or down would have solved anyway. But I have a few complicating factors with the size of the torsion bars I run, plus the 4 speed linkage, road race pan, different shape to the flaming river steering box, etc.
may need a ding or two no matter how well You position the engine & components. I put a 383 in My ex-PoPo Dippy using spool mounts & an A833, and I put a 440 in My
Buddy's '73 satellite (which has a SB specific K-frame in that year) also w/spool mounts. The former I used a combo of early-B and later headers, and the latter has a set
of Hooker Comps and a Moroso 8Qt. pan w/a column shift 727, I built the 3" frt. pipes back to the muffs, then TTI 3" tails..................I nailed the Dippy 1st shot, had to
adj. the Satellite down on the dr. side as much as the pan would allow. Doing anything right takes some hard work, if one is not up for it then leave it alone. The OP asked
for experienced input, Yours has been duly noted, on Your spool mounts the Dougs seem to fit better............................................
