Z-Bar and Clutch Rod Linkage won't line up. Help!?!?!
If you look on the fork w/o the elongated hole - there is a small crease or cutout where the spring goes. So the question is - why did Mopar make two different forks?
It was likely from the spring coming off or maybe stretching over time and then coming off. The only thing you can tell for sure about Ma Mopar is that you never know what to expect.
This is just a guess, but I would say it is a year thing. Just like the bellhousings.
This is why you need to talk to Wayne at Brewers.
He will get you all straightened out.
Every mopar clutch fork diagram i've seen shows the clutch rod going through the main hole on the fork. What those two extra holes are, I have no idea. Does anyone else???
That is for the spring mentioned. My fork is the one with the notch not the holes(shown above) that is installed on a 360.
