younggun2.0
Wow! The room you have now.......is just obscene. LOL. Great job. Been following this, keep up the good work!
ya its like i put a small block in there.
It looks great! Fire up by the weekend?
I love following this thread....always great pictures and info.
what is the part # or application for those TTis?
Idk what you're talking about. It seems like there's more room than a small block. Lol.
Double trans coolers under the trunk floor? At least that's what I'm making out from the pics.
That should keep her cool; not to mention the increased fluid capacity from that set-up!
I like the lines thru the trans mount/cross member....and the swiss cheese job on the mount (s)
Mmmmm sounds good--looks good. Awesome job
i put a wide band in it when i had it all apart. it was pig rich at idle. i cleaned that up and now i have a mid throttle rich condition but it rev's like a mother f*%ker now. Its in the limiter instantly.
I just drove it for the first time this weekend. I had the entire car apart front to rear so i only drove it a few miles and was very very gentle with it. i also dont have it aligned yet. I am having a problem getting the brakes bleed 100% also. I installed a new master cylinder and all new front brakes. I now have wilwood 4 piston brakes at all 4 corners. the pedal will pump up but its mushy. I have air in the lines someplace. i have gravity bleed them and had the girlfriend help with the brake pedal as i worked the bleeder screws. still having problems.
https://youtu.be/b-L0dQMJIaw
Had somewhat the same problem ended up being adjustment on the pushrod also a friend experienced this with the same basic fix
