Old Man Mopar
Righteous Dude
Waiting with interest for the results on this one. Is that now a $1300.00 intake manifold?
Ohhh......and that's not counting the initial cost of the intake itself. I hope it works!Umm, more than that! The invoice from Wilson was $1975........
Haven't heard any feedback! Anybody have more info on the trickflow track heat intake. Anybody know for sure if it will work with the 270's on a B block? Trickflow says yes, but they are also salesman. Any actual testing or port matching been done.
Ready too see that intake on something! Andy, which shortblock will you be testing it on? the dry sump 470??
Why is the only choice in Indy intake and then spend $2,000 on porting
Why do guys keep asking this question? A standard port intake bolts on to the Max Wedge heads and the engine will run (if you can seal the intake port) but really what is the point of putting a standard port intake on a Max Wedge head?
Why bother buying the Max Wedge heads if you are going to stick a standard port intake on there?? If you want to run the standard port intake then buy the 240 heads and have a matched system.
Why is the only choice an Indy intake and then spend $2,000 on porting
WTH are you talking about? Mrl performance went belly up........Andy F is the real deal, and the guy who put forth REAL tech info......mrl performance , glad to have you back with us again .
Andy for president! " I envy some one who has the dinero and set up to do what he does." ALL INFORMATIVE to us peonies !This thread has been beat to death.............thanks to Andy for keeping it interesting and alive....
Yes, I spoke with Eric yesterday and Mike is retiring. Good for him, but sad for us. I was very happy with the work and service from Muscle motors. He did mention, they would consider a small amount of work if they were e-mailed (Mike).I believe both Muscle Motors and MRL have closed.......
You could hide the builds under EPA emissions testing program and set them out the back door when done flogging. LOLIf I was President I wouldn't have any time to work on big block engines! I suppose I could run on the platform of "big blocks for all". Probably wouldn't do so well with the coastal elites........
