Tuna tacos!Tacos ???? I Like Tacos..!!!
Knocking my dick in the dirt. LOLMay the 120 proof Force be with you![]()
Magnum intake cut down with a plate to run an eaton m112 supercharger. Run it with a megasquirt ecu. No need to get rid of the highway gears and should be good for low 13's high 12's. Vacuum acctuated butterfly so you run off the boost just cruising but get into it and instant boost. Fun for spirited driving in the hills.What is it
Yup. Jumper time!So, finally was attempting to start the Demon post trans swap and tunnel ram gasket change. Nothing else. Now it doesnt run unless in crank position. I am using GM HEI module with stock recurved distributor. The ballast resistor has been bypassed so the 12v coil has full voltage always not just at crank. Key to "on" and no power to coil. No power to either wire that would go to ballast resistor normally. Could it be the ignition switch? Any thoughts?
Yup. Jumper time!
Don’t feel bad, I’m lost with electric too.Jumper time? Explain please. I am a whole bunch dumb
Where you tested power at coil?Jumper time? Explain please. I am a whole bunch dumb
You mean like this ???I should know better than to go through old pictures. Like so old they are prints with really ancient 35mm negatives from the early 2000s.
I found some really old pics of cars long ago that were almost forgotten into the all consuming abyss of time.
Really thought that was gonna be a good deal for both of you. Sucks that it didn’t work out.Collecting tools and such to go in the AM to get my GTS out of Paint Jail......Now drinking BEER !!!!
Grab some wire, add alligator clips. Connect one side to the battery and other side to the + on the coil. Crank it. If it starts and runs you either have a bad connector from the switch or the switch itselfJumper time? Explain please. I am a whole bunch dumb
Go get em Mitch. Nice 6 T 8 !!!You mean like this ???
Definitely cool looking@dukeboy_318 this is the thread I got it from. Was cool to see someone thinking the same way. 1965 MMP Barracuda 5.9EFI/46RE IRS Whipple SC
My High School Ride.....Go get em Mitch. Nice 6 T 8 !!!
Welcome to the club...I just woke myself up with a hard snore, I wasn't even aware I was asleep but my thoughts didn't make sense so I should have known.
I am now the the old lady who can fall asleep just like that on the rocking chair LOL.
When i was younger, I thought sleep was a waste of time and now I live for those precious moments on the ol Davenport with my feet up and cozy warm in a refreshing sleep.
I need to scan them. I never drove in high school. I started driving in college, much later than kids usually do. My adoptive parents used to drop off and pick me up everyday from high school.My High School Ride.....![]()
To keep constant battery power.
Sure, it could be...or maybe something else. Make it run properly by jumping first and then back track the circuits that may be at fault. Don’t just throw parts at it.Yes I know I can do that and make it run, but could it be the ignition switch?
