Idaho
- Joined
- Oct 17, 2006
- Messages
- 2,595
- Reaction score
- 274
I have a 408 stroker in the works.
I went with a re-ground cam.
Saves cash at around $150 plus shipping vs $350 for new, plus I can reuse my distributor gear.
Here are the specs from Ken at Oregon Cam Grinders
#1357
230/236 @ .050”, 284/290 adc, .515”/.515” lift (1.6:1 rocker), 108 sep
As you can see it's close the Comp cams thumpr.
I believe its typical to install the Thumpr 4 degrees advanced, bringing the torque curve into a lower RPM range. I also understand some cams have some advance built in.
I can clarify with Ken but just thought I'd ask about this here and get comments on this cam.
#1357
