Jonnylightening
Well hell I was only thinking mid to maybe high 300sthat engine should be 400-450hp all day long at the flywheel with what your telling us probably more
And...that engine should be 400-450hp all day long at the flywheel with what your telling us probably more
At the tires.. sure..Well hell I was only thinking mid to maybe high 300s
I'd rethink the nitrous thing I think your good and have a dependable good running engine and why subject it to nitrous witch is hard on engines. cheap horse power but at a price of longevityWell hell I was only thinking mid to maybe high 300s
Please regale us with all of your personal nitrous experience...I'd rethink the nitrous thing I think your good and have a dependable good running engine and why subject it to nitrous witch is hard on engines. cheap horse power but at a price of longevity
Please do the same lol, pssssssss, pssssssss!, when are you installing the underbody neon lights?, you have done just about everything elsePlease regale us with all of your personal nitrous experience...
I know that's why I started karting..Please do the same lol, pssssssss, pssssssss!, when are you installing the underbody neon lights?, you have done just about everything else
Just ARP Main studsyou should be making close to 500 hp without the nitrous , my 426 stroker made 520 and it was a mild build , with nitrous you should be hitting close to 600 easily . should be a fun ride .
what are the limits for the block ? have you done anything special to the block to increase strength ?
Thats kind of why I posted. I want to make sure I don't go over the limits. Also considering jumping on the E85 bandwagon. I really want to drive the car and at my comperession I'm limited to running race fuel. Its right around $10-$12/gal whereas E85 is around $3/galGood luck , hope it holds up to all the power you'll be making
I should be in the 12.5:1 ballpark. Not 100% yet because I'm not sure what head gaskets I'm runningWhat is your compression?
I love e85, it makes my 13:1 408 quite streetable (runs cool, cheap to fill up, etc)....No idea how e85 works with nitrous though....the last time I ran nitrous I was using gasoline. My guess is it would be no different other than jetting, but I don't know.
I have 11.1 to 1 now, I had 11.3 to 1 with different heads and compression..I should be in the 12.5:1 ballpark. Not 100% yet because I'm not sure what head gaskets I'm running
Interesting he is giving nitrous tuning advice and all he’s ever done is bolt a buch of **** on and sit in his driveway and purge.
Typical.
Don't forget that you need a mood light to shine through your purge, mandatory.
True story I blew the first one up LOL...j Spar had to put a 50 amp fuse on his fancy mood light because he used it so much he overloaded the circuit. Psssssss psssssssssssssaaa
If you want a real good laugh ask if Pittsburgh racer has left his entire nitro setup in his spare bedroom too scared to use it until the bottles went out of date...I needed a good laugh. Thanks gentlemen.
LOL.. oh you mean drag racing where you sit there bored out of your mind in the boiling heat just to go down the track for 6 seconds LOL...not to scared, to busy. Lol. Some of us still race real cars not kiddy carts.
Stop the big man talk... Please it's embarrassing... Karting is far too physically demanding for you to even consider...
Boring... And putting down karting again is showing your ignorance...Boring. You are on the wrong website. You need the “kiddy kart” website
