Dartswinger70
That's actually a good idea if on a desert island and cant get parts...Tap it and plug it..
You mean like taking something apart to patch it rather than replacing it?That's actually a good idea if on a desert island and cant get parts...
I agree many years ago, I knew a guy who filliex the hole with JB Weld or something. Worked like a charm. It ran for quite some time, he said now my alt bearings making noise but still charges. Month or so later the bearings in the water pump went and fan hit radiator. New pump. And New Rad. Old hoses reused and overheated on trip and not the kind of guy that says to hot to drive shut down. Now water in oil.Plugging the weep hole will just make the coolant come out the end of the shaft and onto the pulley itself. This will throw coolant all over the place while driving.
You forgot that it depends on what she looks like.. And also the time of day, closing time?Tap it and plug it..
Yeah, plug the hole. Then when the bearings fail and send the fan through the radiator, it'll be easier to replace the pump as you will have already removed the radiator to replace it.
If you want to make the job much easier, pull the radiator.Okay, the consensus is that I need to replace the pump, which I will. Thanks to all who weighed in!
Yes they do.Two things come to mind, does Flowkooler make a /6 pump? I probably wouldn't put another warranty replacement pump back on. What kind of antifreeze did you use? I haven't had any luck in our old cars with anything other than good old green . The new stuff always leaks out of somewhere for me, always.
drill and tap the weep hole, install a hose barb, install a tube and run it to the exit end of your radiator overflow tubing...maybe it will all equal out...LOL
That was just hilarious!!!! Made my day.Yeah, plug the hole. Then when the bearings fail and send the fan through the radiator, it'll be easier to replace the pump as you will have already removed the radiator to replace it.
because it's held on with nuts and bolts and not a zipper.Why is it so hard to replace it?
/s
Now now now, we all know @cruiser is not afraid to get his fingers dirty.because it's held on with nuts and bolts and not a zipper
nah, nah, no dig at cruiser at all. i just misplaced my sarcasm font was all.Now now now, we all know @cruiser is not afraid to get his fingers dirty.
I was being serious, is it an issue getting the fan off, the shroud off or just that it's a pain in the butt to have to do this so soon.
Fair question. In my experience, any time you open any part of the cooling system you risk creating a leak. In the case of a slant six water pump, you have the pump gasket with its associated metal plate, all of which must seal up properly at the time of installation. Lots of places to leak there. Next are the four hose connections that need to be opened up and then re-secured: The lower radiator hose, the bypass hose with its two connections, and the heater outlet hose. So considering the large pump gasket/metal plate interface, and the four above mentioned connections, there are a lot of opportunities to introduce a leak. If you have a good pump on your motor with sound connections, the last thing you want to do is to start monkeying with everything and end up chasing leaks for the next several months. Yes, if the pump is faulty, in needs to go. Short of this however, I really try to avoid opening coolant connections that I know are good - unless I absolutely have to. And yeah, DanaDart is correct. I'm not the least bit hesitant to get my hands dirty, knuckles skinned, etc. All part of there hobby!Now now now, we all know @cruiser is not afraid to get his fingers dirty.
That's actually not a bad idea.Plug the weep hole with a foam earplug and see if it still leaks on the floor. (After cleaning the suspect area)
That leak could be coming from any of the other areas you described, and just appears to be coming from the weep hole.
That anti-freeze can run down, and you can't see the source.
I use a product for these annoying little leaks when it's not worth it to tear it down to try to find the source of the problem.
Saved me from having to put a head gasket in a farm tractor going on 20 years now, still no leaks.
