Made from 1 3/4" .095" DOM tubing and are designed to tie into the tubular lower radiator support to stiffen the front of your A body. They can also be tied into the factory shock mount to stiffen that area also. I am currently working on brackets to the shock mount area. The tubes are sent long and will require trimming and welding to install. When installing these the battery will have to be relocated to the trunk.
Update the kit now comes with landings for...
Log in or register now.
