Made from 1 1/8" .120" DOM tubing. Designed to give support to the inner fender when installing coilovers. Comes with 1/8" landings for the frame rails. The tubes are cut exact to fit, but welding to install.
Update there is now a second bar to triangulate the hoop for added strength. There are also stiffening plates that come with the kit to box the factory shock tower area.
Log in or register now.
