These are designed to convert from the bayonet style factory shock location to the more common style. They are 6061 aluminum and the hardware in the engine bay is 3/8" stainless steel. The coilover mount is mild steel and can be painted or powder coated. The bolt is fully captured from the top and bottom and is tig welded. I can make these any length that you would like.
These are designed to be used in conjunction with inner fender reinforcement of some kind.
Log in or register now.
